Join Customer Connection to register!
281
Sihanu N
Beginner
Network issue between head office and branch office
Dear all,
Our headoffice and branch officeare connected  by ethernet  lease line.our network range is 192.168.0.0/16.
In headoffice we having 9 cisco 2960 48 port gigabyte swich connected in daisy chain model having lot of servers and desktops .serves having ip address  192.168.12.12,192.168.12.17,192.168.10.19,192.168.10.10
In branch office having 24 desktops connetd with 4   8port dink swich,Branch network is same headofiice having ip range 192.168.40.1 - 192.168.40.24.
Problem is some of the servers and desktops  in head office  cant access from branch office and vise  versa sometimes,  some time it vil get sometime it vil fail...there is no issue with leased line,firewall and all..
please help
Thanks Sihanu N
3 REPLIES 3
Syed Siraj Uddin
Beginner
Hi, is this a flat L2 network between HO & Branch?
Hi Syed,
Yes this is a flat L2 network.there is no router or firewall in the network..
If this is a tryue flat L2 topology (bad idea) then you must make sure all of your hosts have the correct subnet mask, and that should be 255.255.0.0. check some of the affected hosts for this issue.
Then get some routers.
Stephen
http://www.rConfig.com
A free, open source network device configuration management tool, customizable to your needs!
- Always vote on an answer if you found it helpful
========================== http://www.rconfig.com A free, open source network device configuration management tool, customizable to your needs! - Always vote on an answer if you found it helpful
