Network segregation
We are in the process of splitting our servers, printers and workstations into two networks and I would like to hear your thoughts.
Currently, our prinmary network is 10.20.102.0/24. We would like to keep our servers and printers on this network and move workstations to 10.20.104.0/24. As I understand it, I should be able to create a new VLAN with an IP such as 10.20.104.1, create a new DHCP scope on our windows server, then force the workstations to update their IPs. We have a layer 3 switch (Catylst 3560) that would handle routing the traffic between VLANs. Switchports with workstations connected would be configured with "switchport access vlan <104>". In my current knowledge on routing/switching, if you have a device on LAN A with an IP of 10.20.102.55 trying to communicate with a device on LAN B with an IP of 10.20.104.25, it would go to the gateway, since the device isn't on the same LAN, which would then route it to the next hop. What if these LANs are on the same physical network? How would these devices communicate? Also, how will the workstations get IPs from a server on a different network?
Network equipment:
Core Router == Cisco 2811 Router
Switches == 4 Cisco Catalyst 3560
Server:
IBM xSeries running Windows 2003
Workstations:
Windows XP
VLANS:
VLAN 10 == Data (10.20.102.1 -- all printers/workstations/servers)
VLAN 172 == Voice (172.20.102.1 -- phones, phone equipment)
Let me know if you need other information
Antonio Knox
Level 7
Level 7
Let's use your example.  If your Vlan interfaces are configured on the 3560:
interface Vlan10
description LAN A
ip address 10.20.102.1 255.255.255.0
interface Vlan 104
description LAN B
ip address 10.20.104.1 255.255.255.0
Device A has his default gateway set to 10.20.102.1 (interface Vlan10) and device B has his default gateway configured to 10.20.104.1 (interface Vlan104). If device A (10.20.102.55) wants to talk to device B (10.20.104.25), the traffic would have been routed on the 3560 between Vlans 102 and 104.
As for DHCP, if there is a server on a separate network (let's give the DHCP server an ip: 192.168.2.15) you would configure an 'ip helper-address' on each vlan, which will forward each DHCP Discover broadcast to the DHCP server as a unicast packet.  This is done because by default the router (3560) will not forward broadcasts.
interface Vlan10
description LAN A
ip helper-address 192.168.2.15
interface Vlan 104
description LAN B
Hope this makes sense.
Message was edited by: Antonio Knox
Antonio Knox
Level 7
Level 7
interface Vlan10
description LAN A
interface Vlan 104
description LAN B
interface Vlan10
description LAN A
interface Vlan 104
description LAN B
Antonio, Thank you much for your reply! I had asked this previously and have finally gotten the word to move this project forward. The DHCP server is actually on the 10.20.102.0 network. So the 3560 handles forwarding because it's a layer 3 switch, huh? If it wasn't a layer 3, what would happen to these packets? Dropped?
One more follow-up question: the interfaces that the workstations are connected to, they should be configured with SWITCHPORT MODE ACCESS, correct?
Sorry for the late response, but you are correct.  Workstation ports should be configured with 'switchport mode access'.
