05-11-2015 12:35 PM - edited 03-07-2019 11:57 PM
hello Team;
i urgently need support (sorry for my english, i'm speaking usually french), i want to connect one Nexus 2224 to 2 nexus 5000 ( vpc configured); i connect the two uplinks ports on the two nexus 5000, i enabled feature fex on the two nexus 5000 but the nexus 2000 is discovered on only one nexus, when i do "sh flex" on the second, anything.. can you help me please.
05-11-2015 01:52 PM
Since you are connecting the 2224 to 2 5k switches, they both need to have identical configs.
Can you post the relevant configs from both 5ks?
What is the output of "sh vpc"?
05-12-2015 01:24 AM
hello Reza;
thank you for the feedback; find below the config and the sh vpc:
***************************************first switch***************************************************************
!Command: show running-config
!Time: Fri May 15 08:13:01 2009
version 5.2(1)N1(4)
hostname SWX_DC_ECI_HQ_02
feature telnet
feature vrrp
feature tacacs+
cfs eth distribute
feature ospf
feature bgp
feature interface-vlan
feature lacp
feature vpc
feature lldp
feature fex
username admin password 5 $1$c/ldwUKn$0NwjgtFXyC4uHYqHJxyhW/ role network-admin
banner motd #Nexus 5000 Switch
ip domain-lookup
class-map type qos class-fcoe
class-map type queuing class-fcoe
match qos-group 1
class-map type queuing class-all-flood
match qos-group 2
class-map type queuing class-ip-multicast
match qos-group 2
class-map type network-qos class-fcoe
match qos-group 1
class-map type network-qos class-all-flood
match qos-group 2
class-map type network-qos class-ip-multicast
match qos-group 2
snmp-server user admin network-admin auth md5 0x9535bd6d9d844430030ca101bbfb34bd
priv 0x9535bd6d9d844430030ca101bbfb34bd localizedkey
vrf context management
vlan 1,98,107,117,300,328,349-350
vpc domain 1
peer-keepalive destination 10.16.117.10 source 10.16.117.11
delay restore 150
port-profile default max-ports 512
interface Vlan1
interface port-channel10
switchport mode trunk
switchport trunk allowed vlan 98,117,300,328,349-350
spanning-tree port type network
speed 10000
vpc peer-link
interface Ethernet1/1
interface Ethernet1/2
interface Ethernet1/3
interface Ethernet1/4
interface Ethernet1/5
interface Ethernet1/6
interface Ethernet1/7
interface Ethernet1/8
interface Ethernet1/9
interface Ethernet1/10
interface Ethernet1/11
interface Ethernet1/12
interface Ethernet1/13
interface Ethernet1/14
interface Ethernet1/15
interface Ethernet1/16
interface Ethernet1/17
interface Ethernet1/18
interface Ethernet1/19
interface Ethernet1/20
interface Ethernet1/21
interface Ethernet1/22
interface Ethernet1/23
interface Ethernet1/24
interface Ethernet1/25
interface Ethernet1/26
interface Ethernet1/27
interface Ethernet1/28
interface Ethernet1/29
interface Ethernet1/30
interface Ethernet1/31
channel-group 10 mode active
interface Ethernet1/32
interface mgmt0
ip address 10.16.117.11/24
line console
line vty
boot kickstart bootflash:/n5000-uk9-kickstart.5.2.1.N1.4.bin
boot system bootflash:/n5000-uk9.5.2.1.N1.4.bin
SWX_DC_ECI_HQ_02#
*******************************second swich***************************************
!Time: Fri May 15 08:00:03 2009
version 5.2(1)N1(4)
hostname SWX_DC_ECI_HQ_01
feature telnet
feature vrrp
feature tacacs+
cfs eth distribute
feature ospf
feature bgp
feature lacp
feature vpc
feature lldp
feature fex
username admin password 5 $1$mH9pXqtN$01D5BqiMxWztF160H54op. role network-admin
ip domain-lookup
match qos-group 1
match qos-group 2
match qos-group 2
match qos-group 1
match qos-group 2
match qos-group 2
snmp-server user admin network-admin auth md5 0xf8cd973e977f29f89c95d33acde17c82
priv 0xf8cd973e977f29f89c95d33acde17c82 localizedkey
vlan 1
vlan 98
name MIRROIR
vlan 107
name NetworKMgmt
vlan 117
vlan 300
name BusinessApp
vlan 328
name InfraApp
vlan 349
name UCVoice
vlan 350
name Managment
vpc domain 1
peer-keepalive destination 10.16.117.11 source 10.16.117.10
delay restore 150
interface Vlan1
interface port-channel20
speed 10000
vpc peer-link
channel-group 20 mode active
interface mgmt0
ip address 10.16.117.10/24
line console
line vty
SWX_DC_ECI_HQ_01#
***********************************sh vpc output****************************************************
WX_DC_ECI_HQ_02# sh vpc
Legend:
(*) - local vPC is down, forwarding via vPC peer-link
vPC domain id : 1
Peer status : peer adjacency formed ok
vPC keep-alive status : peer is alive
Configuration consistency status : success
Per-vlan consistency status : success
Type-2 consistency status : success
vPC role : primary
Number of vPCs configured : 0
Peer Gateway : Disabled
Dual-active excluded VLANs : -
Graceful Consistency Check : Enabled
Auto-recovery status : Disabled
vPC Peer-link status
id Port Status Active vlans
1 Po10 up 98,117,300,328,349-350
SWX_DC_ECI_HQ_02#
