Nexus 3048 port-channel to 3750G issues.
conley851
I am trying to bring up a trunk between a 3750G stack and (2) Nexus 3048. The uplinks on the 3048's are using 1gig MM SFP. The ports on the 3750 stack are configured as a port channel. I have checked the SFPs, they are valid. I had swapped out fiber patch cables, SFPs. I have included the configurations below, so any help is appreciated!
Configuration on the 3750 stack:
interface GigabitEthernet4/0/7
description ***To C1R2NX3048-1***
switchport trunk allowed vlan 1,255
switchport mode trunk
channel-group 11 mode active
end
interface GigabitEthernet5/0/7
description ***To C1R2NX3048-2***
end
interface Port-channel11
description *** To C1C2NX3048***
end
Nexus #1 Configuration:
interface Ethernet1/49
  description TO-C1R2CS3750-1
  speed 1000
  channel-group 101 mode active
interface port-channel101
  description L2-TO-WLS1C1R1CS3750-2
  vpc 101
  spanning-tree port type normal
  speed 1000
port-channel101 is down (No operational members)
vPC Status: Down, vPC number: 101
  Hardware: Port-Channel, address: 0000.0000.0000 (bia 0000.0000.0000)
  Description: TO-C1R1CS3750-2
  MTU 1500 bytes, BW 100000 Kbit, DLY 10 usec,
  Encapsulation ARPA
  Port mode is trunk
  auto-duplex, auto-speed
  Beacon is turned off
  Input flow-control is off, output flow-control is off
  Switchport monitor is off
  EtherType is 0x8100
  Members in this channel: Eth1/49
  30 seconds input rate 0 bits/sec, 0 bytes/sec, 0 packets/sec
  30 seconds output rate 0 bits/sec, 0 bytes/sec, 0 packets/sec
  Load-Interval #2: 5 minute (300 seconds)
    input rate 0 bps, 0 pps; output rate 0 bps, 0 pps
  RX
    0 unicast packets  0 multicast packets  0 broadcast packets
    0 input packets  0 bytes
Ethernet1/49 is down (Link not connected)
  Hardware: 1000/10000 Ethernet, address: c08c.603d.4f98 (bia c08c.603d.4f98)
  Description: TO-C1R2CS3750-1
  MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec,
  Encapsulation ARPA
  Port mode is trunk
  auto-duplex, 1000 Mb/s, media type is 1G
  Rate mode is dedicated
  EtherType is 0x8100
  Last link flapped never
  Last clearing of "show interface" counters 22:13:17
  RX
Nexus #2 Configuration
  speed 1000
  description TO-C1R1CS3750-2
  vpc 101
  speed 1000
  Hardware: 1000/10000 Ethernet, address: c08c.603d.51d8 (bia c08c.603d.51d8)
  DescriptionTO C1R2CS3750-1
  Encapsulation ARPA
  Port mode is trunk
  EtherType is 0x8100
  Last clearing of "show interface" counters 02:31:20
  RX
    0 jumbo packets  0 storm suppression packets
    0 giants  0 input error  0 short frame  0 overrun   0 underrun
    0 watchdog  0 if down drop
    0 input with dribble  0 input discard(includes ACL drops)
    0 Rx pause
  TX
    0 output packets  0 bytes
    0 jumbo packets
    0 output errors  0 collision  0 deferred  0 late collision
    0 lost carrier  0 no carrier  0 babble
    0 Tx pause
  0 interface resets
  Encapsulation ARPA
  Port mode is trunk
  EtherType is 0x8100
  RX
    0 Rx pause
  TX
    0 jumbo packets
    0 Tx pause
  0 interface resets
5 Replies 5
Wilson Bonilla
Level 3
Level 3
Hello Dan.
- What if you remove the configuration, are the interface coming up as individuals?
- What if you try to loop the fiber cables, for example plug the fiber from the interface 4/0/7 to the 5/0/7 in the same stack, is the interface coming up? try the same test in the 3k.
Can you put in a notepad the output of the following commands and attach it.
- Show log (both switches)
- Show interface status err-disable. (both switches)
- Show inventory (both switches)
- Show version.
Regards.
Wilson B.
Hi Wilson-
Thanks for the reply. To answer your questions:
- If i remove all of the configuration, they do NOT come up. All interfaces still show as not connected.
- I can loop the fiber cables and get lights. I looped the two nexus switches on eth1/49 on both switches successfully, and 4/0/7 to 5/0/7 successfully.
Attached is the output that you were looking for. Thanks again!
Hi Dan.
Thank you for the ouputs, I checked the show inventory, it doesn't populate the transceivers number, only the serial number, and when I search for the transceiver serial number it doesn't show up with any result. So are those cisco transceivers? ...
can you share the transceiver part number!
Regards.
Wilson B
Wilson-
I noticed that as well when I sent this to you. I am going to reboot that switch tonight, because there are all Cisco transceivers in it, and there are some other funny things going on.
I found the issue with this. On the 3750G ports, I had to set 'speed nonegotiate' on the trunks going to the 3k's.
Thank you for the help!
Dear Dan,
The Same Issue I am facing with my Nexus Switch and 3750 Core Switch, Can u Pls Guide me How to Fix this issue?
CDP Neighbour shows the device, but not pinging.
Tamizh
