05-28-2018 11:12 AM - edited 03-08-2019 03:09 PM
This is very interesting thing i found, i am seeing glean counter dropping millions of packet very ~60 second around and during that time very high CPU spiked noticed on proc cpu history graph.
# show policy-map interface control-plane ... ... class-map copp-s-glean (match-any) police pps 500 OutPackets 286253 DropPackets 1243234301 ... ...
After googling found its related to arp flood in network and could be spanning tree related, This is what i am seeing on switches related spanning tree events.
# show spanning-tree internal event-history all 206) Transition at 196700 usecs after Mon May 28 11:57:32 2018 Root: 80ca.2c86.d283.4680 Cost: 2 Age: 1 Root Port: Ethernet1/10 Port: Ethernet1/36 [STP_TREE_EV_MULTI_FLUSH_RCVD] 207) Transition at 224153 usecs after Mon May 28 11:57:33 2018 Root: 80ca.2c86.d283.4680 Cost: 2 Age: 1 Root Port: Ethernet1/10 Port: Ethernet1/36 [STP_TREE_EV_MULTI_FLUSH_RCVD] 208) Transition at 199688 usecs after Mon May 28 11:58:49 2018 Root: 80ca.2c86.d283.4680 Cost: 2 Age: 1 Root Port: Ethernet1/10 Port: Ethernet1/36 [STP_TREE_EV_MULTI_FLUSH_RCVD] 209) Transition at 199563 usecs after Mon May 28 11:58:51 2018 Root: 80ca.2c86.d283.4680 Cost: 2 Age: 1 Root Port: Ethernet1/10 Port: Ethernet1/36 [STP_TREE_EV_MULTI_FLUSH_RCVD] 210) Transition at 204056 usecs after Mon May 28 12:00:08 2018 Root: 80ca.2c86.d283.4680 Cost: 2 Age: 1 Root Port: Ethernet1/10 Port: Ethernet1/36 [STP_TREE_EV_MULTI_FLUSH_RCVD]
We have bunch of Cisco 3850 cat switches also in network and i don't know what command i should use on them to get spanning tree history related spanning tree issue ( I am less familiar to cat OS )
Or any other best way to find out source of origin to find arp flood.
05-29-2018 01:19 AM
on the 3850, use the command 'show spanning-tree detail'.
That said, if possible, post a drawing of the logical setup of your network. You want to make sure that the root switches are correct...
07-04-2018 08:14 PM
