Nexus 3500 upgrade
opnineopnine
Hi all,
I have a 3500 nexus and I have to do the upgrade to the last version  6.0(2)A6(8 my actual versionis  6.0(2)A7(2) ,  when I do the upgrade show I do the upgrade of the kickstart of onlly the NK-OS will be ok?
Is there any command to check if I can have any error?
thanks.
Reza Sharifi
With Nexus, you usually need both the system image and the kickstart.
Here is a link to config guide:
http://www.cisco.com/c/en/us/td/docs/switches/datacenter/nexus3000/sw/upgrade/6_x/Cisco_n3k_Upgrade_Downgrade_6x.html
I did a show install impact and evey thing show success but I only have one question I got this output
Compatibility check is done:
Module  bootable          Impact  Install-type  Reason
     1       yes      disruptive         reset  Forced by the user
Will this be disruptive and need to reboot?
thanks.
