05-17-2018 12:40 PM - edited 03-08-2019 03:03 PM
Hey guys,
i am running vpc&hsrp on my core 3548 switches with about 30 edge switches. Now I need to block comms between only 2 vlans while the other 20 odd vlans have to communicate. Will an ACL work for this? Or is there something I am missing out ? Thanks...
05-17-2018 01:46 PM
Yes, you can use ACL to block the unwanted communications.
05-17-2018 02:49 PM
The issue is that, if ip routing is enabled, and hsrp config running, the amount of xonfig changes would be like refreshing the whole environment. Is there a short version of config i can look in to ?
