07-31-2019 07:52 PM
hello
If I want to limit the multicast packet to 100pps for a switch port egress side, can Nexus 3548-X realize this? If yes, what the config would be? if no, which version OS does support to realize this?
Qu Dong
08-01-2019 02:25 AM
the QoS options on the 3548X switch appear to be very limited. Policing and shaping are not supported at all; the reason being is (most likely) that this switch is built for extreme low latencies, to be used in environments such as stock market exchanges, where nanosecond speeds matter.
So I don't think you can limit multicast traffic the way you want on that platform...
08-01-2019 07:00 AM
