Nexus 3K no traffic statistics on interface vlan
Tariqemad
Hi all , I have cisco nexus 3K .. Im trying to read the traffic on Vlan interface ,, but i can't .. Is there any way to monitor or read the traffic on Vlan Interface ?
 B-Nexus# sh interface vlan 225
Vlan225 is up, line protocol is up, autostate enabled
Hardware is EtherSVI, address is 0042.686d.ca63
Description: Basra BB Internet Address is 10.10.60.4/28
MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec,
reliability 255/255, txload 255/255, rxload 255/255
Keepalive not supported
ARP type: ARPA
L3 in Switched:
ucast: 0 pkts, 0 bytes
Reza Sharifi
You can see the load on the physical interface.
sh int ex/x
you should see something like this
30 seconds input rate 50168 bits/sec, 1 packets/sec
30 seconds output rate 27626072 bits/sec, 2514 packets/sec
Load-Interval #2: 5 minute (300 seconds)
input rate 33.63 Kbps, 3 pps; output rate 24.28 Mbps, 2.15 Kpps
Thanks ... but i have 5 Vlan's trunk on this port ... i need to know the traffic pass through each Vlan .. Not total traffic for all these Vlan's
I do not belive you should able to view that.
BB
