11-23-2011 03:14 PM - last edited on 03-25-2019 04:17 PM by ciscomoderator
I'm trying to get my head around the 'management' vrf and the 'chassis-management' vrf, on my nexus 4000 blade centre switch.
If I have my chassis management vrf interface configured, which is mgmt1 interface, is there a good reason to configure up the 'mgmt0' interface on the management vrf?
I want to do ssh access, tacacs and snmp to manage the switch, and I was considering doing it all through the chassis-management interface, and leaving the mgmt0 interface blank. THe configs that are on this customers existing switches have the mgmt0 and mgmt1 interfaces set as the same IP Address, which I cant see being a good thing.
any advice welcome.
thanks, Simmo.
Solved! Go to Solution.
11-27-2011 11:43 PM
It gets complicated. The way this works is that IBM designs and controls the chassis and Cisco designs the Nexus 4000 switches for their chassis. But IBM still wants to retain control over the chassis via an advanced management module or AMM.i.e. IBM feels they should be able to control the Nexus 4000 module via the Advanced Management Module.
There are 2 management ports on the nexus 4000: one external 10/100/1000BASE-T port (mgmt0) and one internal port (full-duplex 100 Mbps) [mgmt1] connected to the AMM.
There are 3 different VRFs (show vrf all)
Because network engineers are used to managing switches via the CLI, I typically see mgmt1 in "shutdown force" and a static ip address on mgmt0 for out of band management via the front external mgmt 0 port. But if you want to manage the module via the IBM AMM GUI, then you should use the mgmt1 and allow the AMM to give it an ip address via the IO module static ip address and shut down mgmt0. If you want both, then they need 2 different ip addresses.
I believe that the AMM will allow "pass through" mode to the Nexus 4000 CLI so you can reach the CLI via it.
Further information:
http://www.redbooks.ibm.com/abstracts/tips0754.html
On previous blade switches without VRFs, it was possible to loop packets through the AMM and back into the network when it was mis-configured since this internal interface is never blocking. The AMM guide might give you more information since it treats the switch as an IO module.
11-27-2011 11:43 PM
12-05-2011 09:10 PM
thanks lawrence for your comprehensive answer. Cheers, Simmo.
