Popup Hotspot Using ISR 1000 with WiFi/LTE for Teleworkers and Micro Branchesr
3430
Highlighted
Beginner
Nexus 4000
We have Hardware:
  cisco Nexus 4000 Chassis ("20x10GE/supervisor")
  Motorola, e500v2  with 2076512 kB of memory.
  Processor Board ID JAF1513AGCA
From the Cisco Nexus 4001I and 4005I Switch Module for IBM BladeCenter NX-OS Configuration Guide I entered:
conf t
class-map type network-qos class1
  match cos 4
exit
policy-map type network-qos jumbo
  class type network-qos class1
    mtu 9000
exit
exit
system qos
  service-policy type network-qos jumbo
ERROR: network-qos Policy-map jumbo has no match on CoS 0
I did a write erase to take it back to factory defaults and get the same error. In the end I am trying to get all of the Interfaces set to 9000 mtu. Any assistance is appreciated. Thank you for your time.
Everyone's tags (3)
1 ACCEPTED SOLUTION
Highlighted
Re: Nexus 4000
Okay, I see the problem. In your current configuration, there is a network qos policy attached to the system qos config:
system qos
  service-policy type queuing output default-out-policy
  service-policy type network-qos p-nq-8e
In order to configure jumbo frame, you need to change the MTU value in the current policy-map p-nq-8e, or if you want to use a customize network qos policy, you can remove p-nq-8e first and attach a new network qos policy. To simplify it here, use the following commands to change the current network (p-nq-8e) qos's MTU value:
policy-map type network-qos p-nq-8e
  class type network-qos c-nq-8e
     mtu 9000
HTH,
jerry
8 REPLIES 8
Highlighted
Nexus 4000
Can you post all the configuration of class-map, policy-map and system qos?
jerry
Highlighted
Beginner
Re: Nexus 4000
I have attached the sho class-map and policy-map, sho system qos is not option, so I am not sure how to get that information. This is factory default as far as I know, with exception of the attempt to get interface to 9000 MTU and the IP address. Thank you very much for your time.
Highlighted
Beginner
Nexus 4000
Tried class-default as well, not luck.
hchassis(config-pmap-nq)# class type network-qos class-default
ERROR: Class-map class-default of type network-qos not configured
Highlighted
Re: Nexus 4000
Can you get me the output of show running all?
Highlighted
Beginner
Re: Nexus 4000
Thank you
hchassis# sho running all
version 4.1(2)E1(1f)
license grace-period
feature telnet
feature ssh
username admin password 5 !  role network-admin
username USERID password 5 $1$T9bjZYiV$uO5C8x9brdZBp6W0wPCvb1  role network-admin
password strength-check
banner motd # Nexus 4000 Switch #
ssh key rsa 1024
no ssh key dsa
ip domain-lookup
ip host hchassis 192.168.1.29
radius-server timeout 5
radius-server retransmit 1
radius-server deadtime 0
no ip radius source-interface
aaa group server radius radius
    deadtime 0
    use-vrf default
    no source-interface
switchname hchassis
no vlan dot1Q tag native
no system default switchport
system default switchport shutdown
system jumbomtu 9216
no logging event link-status default
no logging event trunk-status default
logging event link-status enable
logging event trunk-status enable
errdisable recovery interval 300
errdisable detect cause link-flap
no errdisable recovery cause link-flap
no errdisable recovery cause udld
no errdisable recovery cause bpduguard
errdisable detect cause loopback
no errdisable recovery cause storm-control
no errdisable recovery cause security-violation
no errdisable recovery cause psecure-violation
no errdisable recovery cause vpc-peerlink
no errdisable recovery cause failed-port-state
class-map type qos match-all class-default
class-map type queuing match-any 1p7q4t-out-pq1
  match cos 1
class-map type queuing match-any 1p7q4t-out-q2
  match cos 2
class-map type queuing match-any 1p7q4t-out-q3
  match cos 0
class-map type queuing match-any 1p7q4t-out-q4
  match cos 4
class-map type queuing match-any 1p7q4t-out-q5
  match cos 5
class-map type queuing match-any 1p7q4t-out-q6
  match cos 6
class-map type queuing match-any 1p7q4t-out-q7
  match cos 7
class-map type queuing match-any 1p7q4t-out-q-default
  match cos 3
  match cos 4
class-map type network-qos c-nq-8e
  match cos 0-7
class-map type network-qos c-nq-5e-drop
  match cos 0,4-7
class-map type network-qos c-nq-6e-drop
  match cos 0,2,4-7
class-map type network-qos c-nq-5e-ndrop
  match cos 1-3
class-map type network-qos c-nq-6e-ndrop
  match cos 1,3
    mtu 9216
policy-map type network-qos p-nq-5e
  class type network-qos c-nq-5e-drop
  class type network-qos c-nq-5e-ndrop
    pause no-drop
    mtu 2240
policy-map type network-qos p-nq-6e
  class type network-qos c-nq-6e-drop
  class type network-qos c-nq-6e-ndrop
    pause no-drop
    mtu 2240
system qos
snmp-server aaa-user cache-timeout 3600
snmp-server protocol enable
no snmp-server globalEnforcePriv
snmp-server tcp-session auth
snmp-server user USERID network-admin auth md5 0x8459c266c6277f13a63c22a1d1787018 priv 0x8459c266c6277f13a63c22a1d1787018 loc
alizedkey
no snmp-server enable traps link
snmp-server enable traps license
no snmp-server enable traps aaa server-state-change
no snmp-server enable traps snmp authentication
snmp-server enable traps link standard-extended
callhome
  switch-priority 7
  destination-profile CiscoTAC-1
  destination-profile CiscoTAC-1 format XML
  destination-profile CiscoTAC-1 message-size 5000000
  destination-profile CiscoTAC-1 message-level 0
  destination-profile full_txt
  destination-profile full_txt format full-txt
  destination-profile full_txt message-size 2500000
  destination-profile full_txt message-level 0
  destination-profile short_txt
  destination-profile short_txt format short-txt
  destination-profile short_txt message-size 4000
  destination-profile short_txt message-level 0
  destination-profile CiscoTAC-1 alert-group cisco-tac
  destination-profile full_txt alert-group all
  destination-profile short_txt alert-group all
  no enable
  duplicate-message throttle
  periodic-inventory notification
  periodic-inventory notification interval  7
  periodic-inventory notification timeofday 08:00
aaa authentication login default local
aaa accounting default local
aaa user default-role
no aaa authentication login error-enable
no aaa authentication login mschap enable
no aaa authentication login ascii-authentication
no radius-server directed-request
vrf context management
vlan 1
  no cin
cdp advertise v2
cdp enable
cdp holdtime 180
cdp timer 60
cdp format device-id system-name
spanning-tree mode rapid-pvst
spanning-tree pathcost method short
no spanning-tree port type edge default
no spanning-tree port type network default
spanning-tree bridge assurance
no spanning-tree loopguard default
spanning-tree vlan 1
spanning-tree vlan 1 priority 32768
spanning-tree vlan 1 hello-time 2
spanning-tree vlan 1 forward-time 15
spanning-tree vlan 1 max-age 20
platform access-list update atomic
no platform access-list update default-result permit
platform rate-limit layer-3 mtu 500
platform rate-limit layer-3 ttl 500
platform rate-limit layer-3 control 10000
platform rate-limit layer-3 glean 100
platform rate-limit layer-3 multicast directly-connected 10000
platform rate-limit layer-3 multicast local-groups 10000
platform rate-limit layer-3 multicast rpf-leak 500
platform rate-limit layer-2 storm-control 0
platform rate-limit access-list-log 100
platform rate-limit copy 30000
platform rate-limit receive 30000
platform ip verify address source broadcast
platform ip verify address source multicast
platform ip verify address destination zero
platform ip verify address identical
platform ip verify address source reserved
platform ip verify checksum
platform ip verify protocol
platform ip verify fragment
platform ip verify length minimum
platform ip verify length consistent
platform ip verify length maximum max-frag
platform ip verify length maximum udp
platform ip verify length maximum max-tcp
platform ip verify tcp tiny-frag
platform ip verify version
platform ipv6 verify length consistent
platform ipv6 verify length maximum max-frag
platform ipv6 verify length maximum udp
platform ipv6 verify length maximum max-tcp
platform ipv6 verify tcp tiny-frag
platform ipv6 verify version
port-channel load-balance ethernet source-dest-ip
port-channel load-balance ethernet source-dest-ip module 1
interface Ethernet1/1
  no description
  switchport
  switchport mode access
  no switchport monitor
  priority-flow-control mode auto
  cdp enable
  spanning-tree port-priority 128
  spanning-tree cost auto
  spanning-tree link-type auto
  no spanning-tree bpduguard
  no spanning-tree bpdufilter
  speed auto
  duplex full
  flowcontrol receive off
  flowcontrol send off
  link debounce
  no beacon
  mtu 1500
  delay 1
  snmp trap link-status
  logging event port link-status default
  logging event port trunk-status default
  bandwidth 10000000
  no bandwidth inherit
  mdix auto
  storm-control broadcast level 100
  storm-control multicast level 100
  storm-control unicast level 100
  medium broadcast
  no shutdown
interface Ethernet1/2
  no description
  switchport
  cdp enable
  speed auto
  duplex full
  link debounce
  no beacon
  mtu 1500
  delay 1
  bandwidth 10000000
  mdix auto
  medium broadcast
  no shutdown
interface Ethernet1/3
  no description
  switchport
  cdp enable
  speed auto
  duplex full
  link debounce
  no beacon
  mtu 1500
delay 1
  bandwidth 1000000
  mdix auto
  medium broadcast
  no shutdown
interface Ethernet1/4
  no description
  switchport
  cdp enable
  speed auto
  duplex full
  link debounce
  no beacon
  mtu 1500
  delay 1
  bandwidth 1000000
  mdix auto
  medium broadcast
  no shutdown
interface Ethernet1/5
  no description
  switchport
  cdp enable
  speed auto
  duplex full
  link debounce
  no beacon
  mtu 1500
  delay 1
  bandwidth 1000000
  mdix auto
  medium broadcast
  no shutdown
interface Ethernet1/6
  no description
  switchport
  cdp enable
speed auto
  duplex full
  link debounce
  no beacon
  mtu 1500
  delay 1
  bandwidth 1000000
  mdix auto
  medium broadcast
  no shutdown
interface Ethernet1/7
  no description
  switchport
  cdp enable
  speed auto
  duplex full
  link debounce
  no beacon
  mtu 1500
  delay 1
  bandwidth 1000000
mdix auto
  medium broadcast
  no shutdown
interface Ethernet1/8
  no description
  switchport
  cdp enable
  speed auto
  duplex full
  link debounce
  no beacon
  mtu 1500
  delay 1
  bandwidth 1000000
  mdix auto
  medium broadcast
  no shutdown
interface Ethernet1/9
  no description
  switchport
cdp enable
  speed auto
  duplex full
  link debounce
  no beacon
  mtu 1500
  delay 1
  bandwidth 1000000
  mdix auto
  medium broadcast
  no shutdown
interface Ethernet1/10
  no description
  switchport
  cdp enable
  speed auto
  duplex full
  link debounce
  no beacon
mtu 1500
  delay 1
  bandwidth 1000000
  mdix auto
  medium broadcast
  no shutdown
interface Ethernet1/11
  no description
  switchport
  cdp enable
  speed auto
  duplex full
  link debounce
  no beacon
  mtu 1500
  delay 1
  bandwidth 1000000
  mdix auto
  medium broadcast
  no shutdown
interface Ethernet1/12
  no description
  switchport
  cdp enable
  speed auto
  duplex full
  link debounce
  no beacon
  mtu 1500
  delay 1
  bandwidth 1000000
  mdix auto
  medium broadcast
  no shutdown
interface Ethernet1/13
  no description
  switchport
  cdp enable
  speed auto
  duplex full
  link debounce
  no beacon
  mtu 1500
  delay 1
  bandwidth 1000000
  mdix auto
  medium broadcast
  no shutdown
interface Ethernet1/14
  no description
  switchport
  cdp enable
  speed auto
  duplex full
  link debounce
  no beacon
  mtu 1500
  delay 1
  bandwidth 1000000
  mdix auto
  medium broadcast
  no shutdown
interface Ethernet1/15
  no description
  switchport
  cdp enable
  speed 10000
  duplex full
  link debounce
  no beacon
  mtu 1500
  delay 1
  bandwidth 10000000
  mdix auto
  medium broadcast
  no shutdown
interface Ethernet1/16
  no description
  switchport
cdp enable
  speed 10000
  duplex full
  link debounce
  no beacon
  mtu 1500
  delay 1
  bandwidth 10000000
  mdix auto
  medium broadcast
  no shutdown
interface Ethernet1/17
  no description
  switchport
  cdp enable
  speed 10000
  duplex full
  link debounce
  no beacon
  mtu 1500
  delay 1
  bandwidth 10000000
  mdix auto
  medium broadcast
  no shutdown
interface Ethernet1/18
  no description
  switchport
  cdp enable
  speed 10000
  duplex full
  link debounce
  no beacon
  mtu 1500
  delay 1
  bandwidth 10000000
  mdix auto
  medium broadcast
  no shutdown
interface Ethernet1/19
  no description
switchport
  cdp enable
  speed 10000
  duplex full
  link debounce
  no beacon
  mtu 1500
  delay 1
  bandwidth 10000000
  mdix auto
  medium broadcast
  no shutdown
interface Ethernet1/20
  no description
  switchport
  cdp enable
  speed 10000
  duplex full
link debounce
  no beacon
  mtu 1500
  delay 1
  bandwidth 10000000
  mdix auto
  medium broadcast
  no shutdown
interface mgmt0
  description
  speed auto
  duplex auto
  no shutdown
  cdp enable
  ip address 172.16.1.29/24
  ip redirects
  ip port-unreachable
  ip arp gratuitous update
  ip arp gratuitous request
interface mgmt1
  description
  speed auto
  duplex auto
  no shutdown
  cdp enable
line console
  no exec-timeout
  terminal length 24
  terminal width 80
line vty
  session-limit 16
  no exec-timeout
boot kickstart bootflash:/n4000-bk9-kickstart.4.1.2.E1.1f.bin
boot system bootflash:/n4000-bk9.4.1.2.E1.1f.bin
system health loopback frequency 60
system clis event-history ha size medium
ip igmp snooping
ip igmp snooping report-suppression
ip igmp snooping link-local-groups-suppression
ip igmp snooping event-history vlan size medium
ip igmp snooping event-history vlan-events size medium
ip igmp snooping event-history igmp-snoop-internal size small
ip igmp snooping event-history mfdm size small
ip igmp snooping event-history mfdm-sum size small
ip igmp snooping event-history vpc size small
ip domain-lookup
ip arp timeout 1500
xml server max-session 8
hchassis#
feature telnet
feature ssh
ssh key rsa 1024
no ssh key dsa
ip domain-lookup
    deadtime 0
    use-vrf default
    no source-interface
switchname hchassis
  match cos 1
  match cos 2
  match cos 0
  match cos 4
  match cos 5
  match cos 6
  match cos 7
  match cos 3
  match cos 4
  match cos 0-7
  match cos 0,4-7
  match cos 0,2,4-7
  match cos 1-3
  match cos 1,3
    mtu 9216
    pause no-drop
    mtu 2240
    pause no-drop
    mtu 2240
system qos
alizedkey
callhome
  switch-priority 7
  no enable
vlan 1
  no cin
cdp advertise v2
cdp enable
cdp holdtime 180
cdp timer 60
  no description
  switchport
  cdp enable
  speed auto
  duplex full
  link debounce
  no beacon
  mtu 1500
  delay 1
  bandwidth 10000000
  mdix auto
  medium broadcast
  no shutdown
  no description
  switchport
  cdp enable
  speed auto
  duplex full
  link debounce
  no beacon
  mtu 1500
  delay 1
  bandwidth 10000000
  mdix auto
  medium broadcast
  no shutdown
  no description
  switchport
  cdp enable
  speed auto
  duplex full
  link debounce
  no beacon
  mtu 1500
delay 1
  bandwidth 1000000
  mdix auto
  medium broadcast
  no shutdown
  no description
  switchport
  cdp enable
  speed auto
  duplex full
  link debounce
  no beacon
  mtu 1500
  delay 1
  bandwidth 1000000
  mdix auto
  medium broadcast
  no shutdown
  no description
  switchport
  cdp enable
  speed auto
  duplex full
  link debounce
  no beacon
  mtu 1500
  delay 1
  bandwidth 1000000
  mdix auto
  medium broadcast
  no shutdown
  no description
  switchport
  cdp enable
speed auto
  duplex full
  link debounce
  no beacon
  mtu 1500
  delay 1
  bandwidth 1000000
  mdix auto
  medium broadcast
  no shutdown
  no description
  switchport
  cdp enable
  speed auto
  duplex full
  link debounce
  no beacon
  mtu 1500
  delay 1
  bandwidth 1000000
mdix auto
  medium broadcast
  no shutdown
  no description
  switchport
  cdp enable
  speed auto
  duplex full
  link debounce
  no beacon
  mtu 1500
  delay 1
  bandwidth 1000000
  mdix auto
  medium broadcast
  no shutdown
  no description
  switchport
cdp enable
  speed auto
  duplex full
  link debounce
  no beacon
  mtu 1500
  delay 1
  bandwidth 1000000
  mdix auto
  medium broadcast
  no shutdown
  no description
  switchport
  cdp enable
  speed auto
  duplex full
  link debounce
  no beacon
mtu 1500
  delay 1
  bandwidth 1000000
  mdix auto
  medium broadcast
  no shutdown
  no description
  switchport
  cdp enable
  speed auto
  duplex full
  link debounce
  no beacon
  mtu 1500
  delay 1
  bandwidth 1000000
  mdix auto
  medium broadcast
  no shutdown
  no description
  switchport
  cdp enable
  speed auto
  duplex full
  link debounce
  no beacon
  mtu 1500
  delay 1
  bandwidth 1000000
  mdix auto
  medium broadcast
  no shutdown
  no description
  switchport
  cdp enable
  speed auto
  duplex full
  link debounce
  no beacon
  mtu 1500
  delay 1
  bandwidth 1000000
  mdix auto
  medium broadcast
  no shutdown
  no description
  switchport
  cdp enable
  speed auto
  duplex full
  link debounce
  no beacon
  mtu 1500
  delay 1
  bandwidth 1000000
  mdix auto
  medium broadcast
  no shutdown
  no description
  switchport
  cdp enable
  speed 10000
  duplex full
  link debounce
  no beacon
  mtu 1500
  delay 1
  bandwidth 10000000
  mdix auto
  medium broadcast
  no shutdown
  no description
  switchport
cdp enable
  speed 10000
  duplex full
  link debounce
  no beacon
  mtu 1500
  delay 1
  bandwidth 10000000
  mdix auto
  medium broadcast
  no shutdown
  no description
  switchport
  cdp enable
  speed 10000
  duplex full
  link debounce
  no beacon
  mtu 1500
  delay 1
  bandwidth 10000000
  mdix auto
  medium broadcast
  no shutdown
  no description
  switchport
  cdp enable
  speed 10000
  duplex full
  link debounce
  no beacon
  mtu 1500
  delay 1
  bandwidth 10000000
  mdix auto
  medium broadcast
  no shutdown
  no description
switchport
  cdp enable
  speed 10000
  duplex full
  link debounce
  no beacon
  mtu 1500
  delay 1
  bandwidth 10000000
  mdix auto
  medium broadcast
  no shutdown
  no description
  switchport
  cdp enable
  speed 10000
  duplex full
link debounce
  no beacon
  mtu 1500
  delay 1
  bandwidth 10000000
  mdix auto
  medium broadcast
  no shutdown
interface mgmt0
  description
  speed auto
  duplex auto
  no shutdown
  cdp enable
  ip redirects
  ip port-unreachable
interface mgmt1
  description
  speed auto
  duplex auto
  no shutdown
  cdp enable
line console
  no exec-timeout
  terminal length 24
  terminal width 80
line vty
  session-limit 16
  no exec-timeout
ip igmp snooping
ip domain-lookup
ip arp timeout 1500
hchassis#
Highlighted
Re: Nexus 4000
system qos
     mtu 9000
HTH,
jerry
Highlighted
Beginner
Nexus 4000
Thank you for your time. I am pinging through with 8950 bytes now.
Highlighted
Re: Nexus 4000
Glad that it solved your problem.
jerry
Content for Community-Ad
