07-28-2010 05:26 AM - edited 03-06-2019 12:13 PM
Could you recommend a cisco book that covers the configuration and intergration of the above mentioned technologies.
cheers
tony
07-28-2010 07:10 AM
Tony,
There is not really a book that explains the technology and integration. Your best resource is the config guides
here is one for VSS:
http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/ios/12.2SX/configuration/guide/vss.html
Reza
11-23-2011 12:01 PM
look these books:
https://www.cisco.com/en/US/docs/solutions/Enterprise/Campus/VSS30dg/VSSdg.pdf
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps708/white_paper_c11_589890.html
I hope I've helped.
Regards.
09-22-2012 02:38 AM
Great post..
I have scenario where in 2 N5k's in a pair are connected to vss (upsttream)in a single port channel. For testing the failover and end to end connnectivity, I tried to ping from a fex on N5k to a switch connected to VSS s/w. In the mean while I rebooted the primary but the ping didn't drop but as soon as the primary N5K was up I could see 6 to 7 ping drops and againn it started pininng continously..
Can u guyz help me with it.
09-22-2012 05:43 AM
no anwer but I intend to install VSS + N5k by end of the year ... so interested by conclusions if you find origin of the problem.
09-24-2012 02:12 AM
could you attach your topology?
Regards.
