Nexus 5000 Tacacs
Dear Mister
I have a little problem.
My customer is using TACP-PLUS ALPHA (F4.0.3.alpha.v9)
Well, the same user than have access to another Cisco equipment, with user test1 by sample, can configure anythiung in the equipment.
But in the nexus 5000, el command "show user-account" indicate just the "network-operator" role.
Well, I patch this situacion with the next commands:
aaa authorization config-commands default group TACSERVER local
aaa authorization commands default group TACSERVER local
Well, when I do a telnet into the nexus, I can shut the interfaces, cofig and aything. But, when I ingress by console, I can not to configyre the interfaces.
Why????
I understand that the Nexus 5000 the Tacacs configuration is global for VTY and Console (different in the Cisco equipment Routers by sample).
Dou you have any idea??
Best Regards
