Nexus 5010 and 5548 make a VPC not available ?
lcd_shouldit
Hi, could I configure vpc use one peer is Nexus 5010 and another peer is 5548 ?
Some more reference for you:
55xx will work fine. You can vpc a 5548 to a 5596. You cannot however vpc a 5010/5020 to a 55xx.
5010/5020 - gatos asic
5548/5596 - carmel asic
Basically they have to be the same kind of asic to work together in vpc.
http://www.vnephos.com/index.php/2011/04/nexus-55xx-50x0-vpc-incompatibility/
Inayath
*Plz rate all usefull posts and mark the thread as answered if it has solved your query.
InayathUlla Sharieff
A Nexus 50x0 cannot be a vPC peer for Nexus 55xx due to different ways of VPC implementation between the two.
REgards
Inayath.
Inayath
Hi,thank you so much for your information.
