Beginner
Nexus 5020 support of HP passive twinax cable
Hi experts,
   I have a customer who is having some issues with 5m passive HP twinax cables, 537965-001, with a Chelsio 10G NIC.  Aside from NIC driver issue, if NX-OS recognizes this SFP+, should it be expected to work in a 5020 running 4.2(1)N1(1)?  Does anyone know whether Cisco has certified passive HP twinax cables?  I have included output to 'transceiver details' to a Cisco twinax and the HP (WL GORE) cables.  Thanks.
Addy
Nexus5020# show interface eth 1/7 transceiver details
Ethernet1/7
    sfp is present
    name is CISCO-MOLEX
    type is SFP-H10GB-CU3M
    part number is 74752-9045
    revision is 07
    serial number is MOC15043853
    nominal bitrate is 10300 MBits/sec
    Link length supported for copper is 3 m(s)
    cisco id is --
    cisco extended id number is 4
   SFP calibration is invalid
Nexus5020# show interface eth 1/8 transceiver details
Ethernet1/8
    sfp is present
    name is WL GORE
    type is 10Gbase-(unknown)
    part number is 537965-001
    revision is C
    serial number is 052010-005
    Link length supported for copper is 5 m(s)
    cisco id is --
2 REPLIES 2
Hall of Fame Community Legend
IF the twinax cable does not have a Cisco logo on it, it won't work.
Engager
Hi Addy,
The list of Cisco certified Twinax cables can be found in the Twinax Cables Certification Matrix for Cisco Nexus 2000 and Nexus 5000 Series Switches Data Sheet.
Content for Community-Ad
July's Community Spotlight Awards
