11-13-2014 09:02 AM - edited 03-07-2019 09:30 PM
Hi everyone
I'm having a problem with deploying a Nexus 5596 in a costumer's network
We have 2 Nexus 5500, connected, through VPC to a Cisco 5585X which owns the default gateways for all the networks. The Nexus has only a SVI in the VLAN 50 for in-band management
The problem is that, if we connect a user in the VLAN 50 (the same one that is configured for Nexus management) that user doesn't get an IP Address from the DHCP Server located in a different VLAN
Here's a simplified network diagram
As far as i could understand, the Nexus MUST relay all the DHCP packets from the VLAN's in which it has configured SVI's (i've tried to remove the SVI's from the Nexus and everything worked just as fine as it works in the other 20 something VLAN's in which I don't have SVI's ).
However, the ASA doesn't relay packets that have already been relayed from another device. So, we must have reached a dead end...or am I picturing this wrong and there is a way to achieve the goal of getting DHCP in the VLAN 50? Hope so...
Here is the dhcp config configuration in both nexus. I've also tried every possible combination for the dhcp global commands ( dhcp relay information and sub-option)
NEXUS-A(config)# show running-config dhcp
!Command: show running-config dhcp
!Time: Thu Nov 13 16:55:35 2014
version 6.0(2)N2(5a)
feature dhcp
ip dhcp snooping
service dhcp
ip dhcp relay
interface Vlan50
ip dhcp relay address 192.168.24.1 <--- DHCP Server
ip dhcp relay address 192.168.4.255 <---- Broadcast address for VLAN50
ip dhcp relay address 192.168.4.250 <---- ASA address for VLAN50 and also the default gateway for this VLAN
ip dhcp relay subnet-broadcast
interface port-channel1
ip dhcp snooping trust
ip arp inspection trust
interface port-channel2
interface port-channel3
interface port-channel4
interface port-channel5
interface port-channel6
interface port-channel7
interface port-channel8
interface port-channel9
interface port-channel10
interface port-channel11
interface port-channel12
interface port-channel13
interface port-channel14
interface port-channel15
interface port-channel400
interface port-channel401
interface port-channel1000
interface Ethernet1/25
ip dhcp snooping vlan 1-1000
Thank you very much
12-01-2015 09:05 AM
This was a bug CSCut21777
It's now fixed
