08-01-2011 06:14 AM - edited 03-07-2019 01:29 AM
I need to enable jumbo frames on a Nexus 5548. I only need this on four 10G ports for Netapp fillers.
Can I enable jumbo frames on only these ports or do I have to do this under the default class? if so will this affect traffic in the default class that does not use jumbo frames?
08-01-2011 06:30 AM
In my experience, if you enable jumbo frame in your datacenter, you better do it on every switch and port. It will not affect other trafic in class default.
08-01-2011 02:41 PM
There are two type of MTU in the Nexus 5500. L2 and L3.
For L2, you have to do it under the network qos, which is a system wide configuration.
For L3, it is per interface. Meaning you have to apply it on every SVIs, L3 PO and L3 physical interfaces.
HTH,
jerry
