I am trying to setup a rate limit on fex ports (modl is N2K-C2248TP-1GE ) of a 5548UP (non L3) - Software version is : version 6.0(2)N2(2)
I have tried the following setup without success :
ip access-list ACL_CUST
10 permit ip 10.100.100.1/32 10.100.100.2/32
20 permit ip 10.100.100.2/32 10.100.100.1/32
class-map type qos match-all CMQOS_CUST
match access-group name ACL_CUST
policy-map type qos PMQOS_CUST
class CMQOS_CUST
police cir percent 1 bc 200 ms conform transmit violate drop
interface Ethernet161/1/11 - 12
service-policy type qos input PMQOS_CUST
And also tried to use this confioguration :
class-map type qos match-all CMQOS_LIMIT_BP_CUST
match cos 0-7
policy-map type qos PMQOS_LIMIT_BP_CUST
class CMQOS_LIMIT_BP_CUST
service-policy type qos input PMQOS_LIMIT_BP_CUST
The problem is that the bandwith restriction (1 percent of 1Gbit/s shoud be 10Mbit/s) is not working and apparently no restriction is applied
If someone could help me to resolve this issue it would be greatly appreciated
I do have followed this guide
http://www.cisco.com/en/US/docs/switches/datacenter/nexus5000/sw/qos/503_n1_1/cisco_nexus_5000_qos_config_gd_503_chapter3.html
Thanks !
