02-01-2012 02:38 AM - edited 03-07-2019 04:40 AM
i have a requirement to provide VOIP recording using SPAN sessions on a NX 5548.
Can someone confirm please whether a VLAN can be used as a source in multiple SPAN sessions on a 5548 ?
I.e.
monitor session 1 – source vlan AA, dest port X
monitor session 2 – source vlan AA, dest port Y
I understand that a physical port can be used in multiple SPAN sessions but am not clear if this also applies to VLAN's
thanks in advance
02-01-2012 03:16 AM
I am afraid that you cannot do that.
See
Characteristics of Source Ports
A source port, also called a monitored port, is a switched interface that you monitor for network traffic analysis. The switch supports any number of ingress source ports (up to the maximum number of available ports on the switch) and any number of source VLANs or VSANs.
A source port has these characteristics:
Riccardo
02-01-2012 03:26 AM
ok i had hoped this was not the case as another post seemed to suggest physical ports could be used more than once in SPAN sessions..
see
02-01-2012 04:34 AM
indeed, in that thread the poster suggested that such configuration is possible. Actually we don't know if that worked for real.
Honestly I don't have first-hand experience on this.
I suggest you to give a go in the lab and check this out. Officially it should not work though.
Riccardo
