Nexus 5548 TACACS+ config question?
BryanPMiller
I am working for an Air Force client and am adding a handful of 5548s into their network.  My question is how Tacacs+ is configured.  My hands are tied in regards to testing in an operational environment so I want to ensure the configs are correct prior to deployment/maintenance window and avoid any remote issues.
I have read the "Cisco Press - TACACS+" config guide and it was somewhat vague in regards to operational deployment.
My basic NX-OS configs are as follows:
- feature tacacs+
- tacacs-server key 7 "002A52xxxxxxxxxxxxxxxx8"
- tacacs-server host 128.xx.xx.xx timeout 10
- tacacs-server directed-request
When I try to set the following command string, aaa authentication login default group tacacs+ local, the NX-OS asks me the input a "server group name".  There are no server groups configured.  Do I need them? Can I get by without configuring a group name because the client probably will not. The Cisco IOS devices are configured with normal aaa authentication/authorization parameters.
Also, do the VTY ports default to sshv2 and the correct tacacs+ parameters with the "transport input ssh" command (not available)?
Any help would be greatly aprreciated.
Bryan
vmiller
Level 7
Level 7
there should be a "built in" group for tacacs and radius.
Configuring Default Login Authentication Methods
The authentication methods include the following:
  • Global pool of RADIUS servers
  • Named subset of RADIUS or TACACS+ servers
  • Local database on the Nexus 5000 Series switch
  • Username only
The default method is local.
Before you configure default login authentication methods,  configure RADIUS or TACACS+ server groups as needed. To configure  default login authentication methods, perform this task:
SUMMARY STEPS
1.          switch# configure terminal
2.          switch(config)# aaa authentication login default {group        group-list [none] | local | none}
3.          switch(config)# exit
4.          (Optional)                                    switch# show aaa authentication
5.          (Optional)                                    switch# copy running-config startup-config
DETAILED STEPS
Command or ActionPurpose
Step 1switch# configure terminal
Enters configuration mode.
Step 2switch(config)# aaa authentication login default {group        group-list [none] | local | none}
Configures the default authentication methods.
The        group-list        argument consists of a space-delimited list of group names. The group names are the following:
  • radius                         —Uses the global pool of RADIUS servers for authentication.
  • named-group        —Uses a named subset of TACACS+ or RADIUS servers for authentication.
The                       local                    method uses the local database for authentication. The                       none                    method uses the username only.
The default login method is                       local                   , which is used when no methods are configured or when all of the configured methods do not respond.
Marvin Rhoads
Build a aaa group and aaa commands like as follows:
feature tacacs+
aaa group server tacacs+ AAA-Servers
    server [1st server IP]
    server [optional - 2nd server IP]
    source-interface [svi consistent with your device deifntion in tacacs server]
aaa authentication login default group AAA-Servers local
aaa authorization config-commands default group AAA-Servers none
aaa authorization commands default group AAA-Servers none
aaa accounting default group AAA-Servers
That should get you good to go.
For more details, please refer here.
Marvin Rhoads
Also, your second question is answered here as follows:
Cisco NX-OS Software defaults to SSHv2 with a 1024 bit RSA key.  The SSH key can be modified to a DSA/RSA key up to 2048 bits to increase security.
