09-30-2020 12:21 PM
Hi, please experts help me with this, could a Nexus 5548-UP be managed without DL2 module ?, because we need to insert an expansion module for 10 fiber ports without losing management.
Thanks in advance...
09-30-2020 01:02 PM
is nexus 5548 running already and you want to add another module to it ? is this correct?
how are you managing now this switch SSH? if so can you show the version and show modules to understand what is installed. ?
10-01-2020 07:17 AM
Hello Balaji, thanks for your reply,
Yes
Yes we use SSH to manage the switch, the show module command is attached, hope you can help me with this...
09-30-2020 05:12 PM
The management port separate has nothing to do with L2, L3 cards, or an explanation module.
10-01-2020 07:28 AM
Hi Reza, thanks for your reply,
Well the thing is, I would like to know is that if there is any other way to manage the switch without the L3 module, the switch is running and it is required to add a module to get more 10GB ports, I hope you understand what i mean and you could help me with this, if you need more details please let me know.
We use SSH to manage the switch, the show module command is attached.
Thanks in advance....
10-01-2020 07:47 AM
You can manage the switch without an L3 module or expansion module. If the switch is layer-2 only, all you need is an SVI on the switch with IP address. You can then ssh, talent, etc.. to that IP and manage the switch. If you are managing the switch out-of-band using mgmt0 interface, than you just need an IP on the OOB port.
