Nexus 5548up VPC pair Layer 3 and ASA connection
adamwhelan4
Hi Everyone,
     I have a pair of Nexus 5548up in VPC mode also doing layer 3 routing between some vlans. I have an active/standby setup for my ASA firewalls. What is the appropriate method for routing traffic from the Nexus over the the ASA. Do I need to created routed ports? Or do I create another SVI/Vlan and just assign that port into this VLAN? Please let me know if you need more clarification.
Thank You
6 Replies 6
dukenuk96
Level 3
Level 3
if you have two ASAs in active/standby failover configuration, it is better to connect them two both Nexuses - one ASA to one Nexus, other ASA to another Nexus. You will not be able to configure different IP networks on same interfaces for your ASA, so you will need to use SVIs on Nexuses and pass this VLAN to ASA posrts.
   I do plan on connecting the active firewall to the primary Nexus and the standby firewall the secondary Nexus. I believe you answered my question about the SVI. I plan to create a point to point VLAN/SVI that will use hrsp. I will then put the uplink ports to the firewalls into that VLAN.
Yes, you are going right way.
OK thank you. I got the following advice in another thread but I was a bit confused by it.
"As for routed interfaces, for such setup you need SVI for egress vlan on Nexus (default gateway) and BVI interface bridging ingress and egress vlans on ASA."
Strange advice, not sure what is meant exactly :)
Depends how you want to configure ASA "transparent or routed mode" . In routed mode, BVI not needed see below sample configuration below for dual and single connection and attachment. I preferred dual connections cause its provide redundancy and high availability.
 For ASA with port-channel
interface Port-channel30
 description Uplink Inside
 lacp max-bundle 8
 nameif Inside (VLAN X)
 security-level 100
 ip address 192.168.1.1 255.255.255.0 standby 192.168.1.2
interface GigabitEthernet1/0
 channel-group 30 mode active
 no nameif
 no security-level
 no ip address
interface GigabitEthernet1/1
 no nameif
 no security-level
 no ip address
Nexus
interface Ethernet1/3
  description Inside-Primary
  switchport access vlan X
  speed 1000
  no negotiate auto
  channel-group 32 mode active
interface Ethernet1/4
  description Inside-backup
  speed 1000
  no negotiate auto
  channel-group 33 mode active
interface port-channel 32
  speed 1000
  no negotiate auto
  vpc 32
interface port-channel 33
  speed 1000
  no negotiate auto
  vpc 33
ASA single connection
Nexus
  speed 1000
  no negotiate auto
  speed 1000
  no negotiate auto
  vpc 32
 Hope this sample configuration helps out
