10-18-2012 09:41 AM - edited 03-07-2019 09:33 AM
we installed copper and fiber sfp modules in the 2232PP and none would link up. we pulled the sfp modules out and entered the speed 1000 command and re-inserted the module with no success. the same sfp modules works fine in every other cisco device. we must be missing something. running latest nx-os software.
COH-Nexus-02# sh int Eth101/1/1 status
Port Name Status Vlan Duplex Speed Type
Eth101/1/1 -- unknown e 40 full 1000 --
COH-Nexus-02#
COH-Nexus-02# sh int Eth101/1/1 transceiver det
Ethernet101/1/1
transceiver is present
type is 1000base-T
name is CISCO-METHODE
part number is SP7041_Rev_F
revision is F
serial number is 00000MTC16240871
nominal bitrate is 1300 MBit/sec
Link length supported for copper is 100 m
cisco id is --
cisco extended id number is 4
DOM is not supported
COH-Nexus-02#
10-18-2012 11:03 AM
What is Ethernet101/1/1 connected to?
10-18-2012 11:12 AM
please disregard, the fabric extender is 10ge only. thanks.
10-18-2012 01:09 PM
THESE ARE THE TRANSCEIVERS SUPPORTED ON THE FEX 2232PP :
• 1/10 Gigabit Ethernet ports SFP/SFP+ (Supported transceiver and cables include Twinax SFP-H10GB-CU1M, SFP-H10GB-CU3M, SFP-H10GB-CU5M, SFP-H10GB-ACU7M, and SFP-H10GB-ACU10M, include SFP+ SFP-10G-SR, SFP-10G-LR, and include SFP GLC-T, GLC-SX-MM, GLC-LH-SM, SFP-GE-T, SFP-GE-S, SFP-GE-L)
Posted by WebUser Adil Taleb from Cisco Support Community App
10-18-2012 01:10 PM
Is the 5548UP have the LAN BASE licences installed on?
