Dear All,
Can Nexus 5596 support more than 1 N55-M160L3-V2 layer 3 module?
Best Regards,
No. If you try to configure a 5596 with multiple N55-M160L3-V2 in the configuration tool you will receive an error "Max [1] N55-M160L3 can be selected per chassis."
Why would you want to put two (or more) Layer 3 module into a single Nexus chassis???
Because the Nexus 5596 L2 forwarding rate is line rate, but we should enable Layer 3 function, if installed one Layer 3 module only, the Layer 3 forwarding rate is 160Gbps only.
You can't make it any faster, Jackson.
