03-22-2017 04:50 PM - edited 03-08-2019 09:52 AM
We purchased a couple Nexus 5596T Switches that came with older firmware on them:
n5000-uk9.5.2.1.N1.4.bin
and
n5000-uk9-kickstart.5.2.1.N1.4.bin
I would like to update the firmware before putting them into production. I notice there is version 5, 6, and 7 software versions available for these switches. Does anyone have a recommendation as to which version is best (and most stable) for production use? I will be connecting various EMC and Cisco Storage and Server devices to these switches at 10 Gbit speeds either 10GigBaseT, 10GigLR SFP+, or 10Gig SFP+ Direct Attach Cables?
What would you recommend?
Also, do I need to load the kickstart or main software first? I do have Cisco Prime Infrastructure and am planning to push the software updates from there.
03-22-2017 05:35 PM
It is hard to tell what version is stable as almost every version has its own bugs. It also depend on the feature set you will be using. I recommend you pick a version in 7 series, read the release notes carefully, load and test it before putting it in production. Yes, you need both kickstart and the system image.
03-23-2017 09:17 AM
Thanks for the advice, I'll take a look at the version 7 images. We are just using the basic layer 2 features, so nothing fancy as far as feature sets.
03-23-2017 12:07 PM
It appears to be that Cisco doesn't recommend a certain code version for Nexus 5596T. As Reza stated it's a critical point to carefully consider the right code for your environment. As always, test before deploying to production.
Please see:
Table 6 Cisco NX-OS Release 7.0(8)N1(1) Supported Upgrade and Downgrade Paths
6.0(2)N2(4)—6.0(2)N2(7) |
23.Possibility of ISSU failure if you are upgrading to Cisco NX-OS release 7.0(6)N1(1) or earlier when multi-step ISSU is performed. For multi-step ISSU, it is recommended to upgrade directly to Cisco NX-OS Release 7.0(7)N1(1) or 7.0(8)N1(1). See CSCuw78727 for details. 24.Performing a multi-step ISSU from Cisco NX-OS release 5.1(3)Nx(x) to 5.2(1)N1(x) to 7.0(5)N1(1) could result in fabric logout of FCoE hosts and vFCs to remain in an initializing state. 25.Non-disruptive upgrade is not supported for Cisco NX-OS Release 5.2(1)N1(8a). Note |
and its limitation section.
http://www.cisco.com/c/en/us/td/docs/switches/datacenter/nexus5500/sw/release/notes/7x/Nexus5500_Release_Notes_7x.html
Good luck!
