12-12-2012 01:13 AM - edited 03-07-2019 10:33 AM
Hi Team,
We are getting some error logs like below on nexus switch 5K, Please check and let me know why we are getting this kind of error.
If you want any other logs please let me know.
Logs:
2012 Dec 11 10:40:02 NX5K %ETHPORT-5-IF_DOWN_ADMIN_DOWN: Interface Ethernet121/1/40 is down (Administratively down)
2012 Dec 11 10:40:02 NX5K %ETHPORT-5-IF_DOWN_ADMIN_DOWN: Interface Ethernet121/1/41 is down (Administratively down)
2012 Dec 11 10:40:02 NX5K %ETHPORT-5-IF_DOWN_ADMIN_DOWN: Interface Ethernet121/1/42 is down (Administratively down)
2012 Dec 11 10:40:02 NX5K %ETHPORT-5-IF_DOWN_ADMIN_DOWN: Interface Ethernet121/1/43 is down (Administratively down)
2012 Dec 11 10:40:02 NX5K %ETHPORT-5-IF_DOWN_ADMIN_DOWN: Interface Ethernet121/1/44 is down (Administratively down)
2012 Dec 11 10:40:02 NX5K %ETHPORT-5-IF_DOWN_ADMIN_DOWN: Interface Ethernet121/1/45 is down (Administratively down)
2012 Dec 11 10:40:02 NX5K %ETHPORT-5-IF_DOWN_ADMIN_DOWN: Interface Ethernet121/1/46 is down (Administratively down)
2012 Dec 11 10:40:02 NX5K %ETHPORT-5-IF_DOWN_ADMIN_DOWN: Interface Ethernet121/1/47 is down (Administratively down)
2012 Dec 11 10:40:02 NX5K %ETHPORT-5-IF_DOWN_ADMIN_DOWN: Interface Ethernet121/1/48 is down (Administratively down)
2012 Dec 11 10:40:02 NX5K %PFMA-2-FEX_STATUS: Fex 121 is online
2012 Dec 11 10:40:02 NX5K %NOHMS-2-NOHMS_ENV_FEX_ONLINE: FEX-121 On-line
NX5K#
NX5K#
NX5K# sh fex 121
FEX: 121 Description: FEX121 state: Online
FEX version: 5.0(3)N1(1c) [Switch version: 5.0(3)N1(1c)]
Extender Model: N2K-C2248TP-1GE, Extender Serial: FOC16063CRQ
Part No: 73-13232-01
pinning-mode: static Max-links: 1
Fabric port for control traffic: Eth1/5
Fabric interface state:
Po121 - Interface Up. State: Active
Eth1/5 - Interface Up. State: Active
NX5K# `
2012 Nov 16 20:04:31 NX5K %ETHPORT-5-IF_DOWN_ADMIN_DOWN: Interface Ethernet121/1/44 is down (Administratively down)
2012 Nov 16 20:04:31 NX5K %ETHPORT-5-IF_DOWN_ADMIN_DOWN: Interface Ethernet121/1/45 is down (Administratively down)
2012 Nov 16 20:04:31 NX5K %ETHPORT-5-IF_DOWN_ADMIN_DOWN: Interface Ethernet121/1/46 is down (Administratively down)
2012 Nov 16 20:04:31 NX5K %ETHPORT-5-IF_DOWN_ADMIN_DOWN: Interface Ethernet121/1/47 is down (Administratively down)
2012 Nov 16 20:04:31 NX5K %ETHPORT-5-IF_DOWN_ADMIN_DOWN: Interface Ethernet121/1/48 is down (Administratively down)
2012 Nov 16 20:04:31 NX5K %PFMA-2-FEX_STATUS: Fex 121 is online
2012 Nov 16 20:04:31 NX5K %NOHMS-2-NOHMS_ENV_FEX_ONLINE: FEX-121 On-line
2012 Nov 19 21:07:40 NX5K %ETH_PORT_CHANNEL-5-FOP_CHANGED: port-channel121: first operational port changed from Eth
ernet1/5 to none
2012 Nov 19 21:07:40 NX5K %ETH_PORT_CHANNEL-5-PORT_DOWN: port-channel121: Ethernet1/5 is down
2012 Nov 19 21:07:40 NX5K %ETH_PORT_CHANNEL-5-PORT_DOWN: port-channel121: port-channel121 is down
2012 Nov 19 21:07:40 NX5K %FEX-5-FEX_PORT_STATUS_NOTI: Uplink-ID 2 of Fex 121 that is connected with Ethernet1/5 ch
anged its status from Active to Disconnected
2012 Nov 19 21:07:40 NX5K %PFMA-2-FEX_STATUS: Fex 121 is offline
2012 Nov 19 21:07:40 NX5K %NOHMS-2-NOHMS_ENV_FEX_OFFLINE: FEX-121 Off-line (Serial Number )
2012 Nov 19 21:07:40 NX5K %ETHPORT-5-IF_DOWN_INTERFACE_REMOVED: Interface Ethernet121/1/1 is down (Interface remove
d)
2012 Nov 19 21:07:40 NX5K %ETHPORT-5-IF_DOWN_INTERFACE_REMOVED: Interface Ethernet121/1/2 is down (Interface remove
d)
2012 Nov 19 21:07:40 NX5K %ETHPORT-5-IF_DOWN_INTERFACE_REMOVED: Interface Ethernet121/1/3 is down (Interface remove
d)
2012 Nov 19 21:07:40 NX5K %ETHPORT-5-IF_DOWN_INTERFACE_REMOVED: Interface Ethernet121/1/4 is down (Interface remove
d)
2012 Nov 19 21:07:40 NX5K %ETHPORT-5-IF_DOWN_INTERFACE_REMOVED: Interface Ethernet121/1/5 is down (Interface remove
d)
2012 Nov 19 21:07:40 NX5K %ETHPORT-5-IF_DOWN_INTERFACE_REMOVED: Interface Ethernet121/1/6 is down (Interface remove
NX5K# sh vpc brief
Legend:
(*) - local vPC is down, forwarding via vPC peer-link
vPC domain id : 11
Peer status : peer adjacency formed ok
vPC keep-alive status : peer is alive
Configuration consistency status: success
Per-vlan consistency status : success
Type-2 consistency status : success
vPC role : secondary, operational primary
Number of vPCs configured : 99
Peer Gateway : Enabled
Dual-active excluded VLANs : -
Graceful Consistency Check : Enabled
vPC Peer-link status
id Port Status Active vlans
1 Po200 up 1,960-967,980-981,1100-1103,1105-1108,1110-1113,11
15-1118,1120-1123,1125-1128,1130-1133,1135-1138,11
40,1145,1150,1155,1160,1165,1300-1303,1305-1308,13
10-1313,1315-1318,1320-1323,1325-1328,1330-1333,13
35-1338,1340,1345,1350,1355,1360,1365,1500-1503,15 ....
vPC status
id Port Status Consistency Reason Active vlans
21 Po21 up success success 1,960-967,9
80-981,1100
-1103,1105-
1108,1110-1
113,111....
121 Po121 up success success -
122 Po122 up success success -
122880 Eth121/1/1 down* failed Consistency Check Not -
Performed
122881 Eth121/1/2 down* failed Consistency Check Not -
Performed
122882 Eth121/1/3 down* failed Consistency Check Not -
Performed
122883 Eth121/1/4 down* failed Consistency Check Not -
Performed
122884 Eth121/1/5 down* failed Consistency Check Not -
Performed
122885 Eth121/1/6 down* failed Consistency Check Not -
Performed
122886 Eth121/1/7 down* failed Consistency Check Not -
Performed
122887 Eth121/1/8 down* failed Consistency Check Not -
Performed
122888 Eth121/1/9 down* failed Consistency Check Not -
Performed
122889 Eth121/1/10 down* failed Consistency Check Not -
Performed
122890 Eth121/1/11 down* failed Consistency Check Not -
Performed
122891 Eth121/1/12 down* failed Consistency Check Not -
Performed
122892 Eth121/1/13 down* failed Consistency Check Not -
Performed
122893 Eth121/1/14 down* failed Consistency Check Not -
Performed
122894 Eth121/1/15 down* failed Consistency Check Not -
Performed
122895 Eth121/1/16 down* failed Consistency Check Not -
Performed
122896 Eth121/1/17 down* failed Consistency Check Not -
Performed
122897 Eth121/1/18 down* failed Consistency Check Not -
Performed
122898 Eth121/1/19 down* failed Consistency Check Not -
Performed
122899 Eth121/1/20 down* failed Consistency Check Not -
Performed
122900 Eth121/1/21 down* failed Consistency Check Not -
Performed
122901 Eth121/1/22 down* failed Consistency Check Not -
Performed
122902 Eth121/1/23 down* failed Consistency Check Not -
Performed
122903 Eth121/1/24 down* failed Consistency Check Not -
Performed
122904 Eth121/1/25 down* failed Consistency Check Not -
Performed
122905 Eth121/1/26 down* failed Consistency Check Not -
Performed
122906 Eth121/1/27 down* failed Consistency Check Not -
Performed
122907 Eth121/1/28 down* failed Consistency Check Not -
Performed
122908 Eth121/1/29 down* failed Consistency Check Not -
Performed
122909 Eth121/1/30 down* failed Consistency Check Not -
Performed
122910 Eth121/1/31 down* failed Consistency Check Not -
Performed
122911 Eth121/1/32 down* failed Consistency Check Not -
Performed
122912 Eth121/1/33 down* failed Consistency Check Not -
Performed
122913 Eth121/1/34 down* failed Consistency Check Not -
Performed
122914 Eth121/1/35 down* failed Consistency Check Not -
Performed
122915 Eth121/1/36 down* failed Consistency Check Not -
Performed
122916 Eth121/1/37 down* failed Consistency Check Not -
Performed
122917 Eth121/1/38 down* failed Consistency Check Not -
Performed
122918 Eth121/1/39 down* failed Consistency Check Not -
Performed
122919 Eth121/1/40 down* failed Consistency Check Not -
Performed
122920 Eth121/1/41 down* failed Consistency Check Not -
Performed
122921 Eth121/1/42 down* failed Consistency Check Not -
Performed
122922 Eth121/1/43 down* failed Consistency Check Not -
Performed
122923 Eth121/1/44 down* failed Consistency Check Not -
Performed
122924 Eth121/1/45 down* failed Consistency Check Not -
Performed
122925 Eth121/1/46 down* failed Consistency Check Not -
Performed
122926 Eth121/1/47 down* failed Consistency Check Not -
Performed
122927 Eth121/1/48 down* failed Consistency Check Not -
Performed
123904 Eth122/1/1 down* failed Consistency Check Not -
Performed
123905 Eth122/1/2 down* failed Consistency Check Not -
Performed
123906 Eth122/1/3 down* failed Consistency Check Not -
Performed
123907 Eth122/1/4 down* failed Consistency Check Not -
Performed
123908 Eth122/1/5 down* failed Consistency Check Not -
Performed
123909 Eth122/1/6 down* failed Consistency Check Not -
Performed
123910 Eth122/1/7 down* failed Consistency Check Not -
Performed
123911 Eth122/1/8 down* failed Consistency Check Not -
Performed
123912 Eth122/1/9 down* failed Consistency Check Not -
Performed
123913 Eth122/1/10 down* failed Consistency Check Not -
Performed
123914 Eth122/1/11 down* failed Consistency Check Not -
Performed
123915 Eth122/1/12 down* failed Consistency Check Not -
Performed
123916 Eth122/1/13 down* failed Consistency Check Not -
Performed
123917 Eth122/1/14 down* failed Consistency Check Not -
Performed
123918 Eth122/1/15 down* failed Consistency Check Not -
Performed
123919 Eth122/1/16 down* failed Consistency Check Not -
Performed
123920 Eth122/1/17 down* failed Consistency Check Not -
Performed
123921 Eth122/1/18 down* failed Consistency Check Not -
Performed
123922 Eth122/1/19 down* failed Consistency Check Not -
Performed
123923 Eth122/1/20 down* failed Consistency Check Not -
Performed
123924 Eth122/1/21 down* failed Consistency Check Not -
Performed
123925 Eth122/1/22 down* failed Consistency Check Not -
Performed
123926 Eth122/1/23 down* failed Consistency Check Not -
Performed
123927 Eth122/1/24 down* failed Consistency Check Not -
Performed
123928 Eth122/1/25 down* failed Consistency Check Not -
Performed
123929 Eth122/1/26 down* failed Consistency Check Not -
Performed
123930 Eth122/1/27 down* failed Consistency Check Not -
Performed
123931 Eth122/1/28 down* failed Consistency Check Not -
Performed
123932 Eth122/1/29 down* failed Consistency Check Not -
Performed
123933 Eth122/1/30 down* failed Consistency Check Not -
Performed
123934 Eth122/1/31 down* failed Consistency Check Not -
Performed
123935 Eth122/1/32 down* failed Consistency Check Not -
Performed
123936 Eth122/1/33 down* failed Consistency Check Not -
Performed
123937 Eth122/1/34 down* failed Consistency Check Not -
Performed
123938 Eth122/1/35 down* failed Consistency Check Not -
Performed
123939 Eth122/1/36 down* failed Consistency Check Not -
Performed
123940 Eth122/1/37 down* failed Consistency Check Not -
Performed
123941 Eth122/1/38 down* failed Consistency Check Not -
Performed
123942 Eth122/1/39 down* failed Consistency Check Not -
Performed
123943 Eth122/1/40 down* failed Consistency Check Not -
Performed
123944 Eth122/1/41 down* failed Consistency Check Not -
Performed
123945 Eth122/1/42 down* failed Consistency Check Not -
Performed
123946 Eth122/1/43 down* failed Consistency Check Not -
Performed
123947 Eth122/1/44 down* failed Consistency Check Not -
Performed
123948 Eth122/1/45 down* failed Consistency Check Not -
Performed
123949 Eth122/1/46 down* failed Consistency Check Not -
Performed
123950 Eth122/1/47 down* failed Consistency Check Not -
Performed
123951 Eth122/1/48 down* failed Consistency Check Not -
Performed
NX5K#
Please be make sure ASAP..........
Waiting for your answer?..
Sen
12-18-2012 08:28 AM
Do you have two Nexus 5Ks as peers and have the FEXs connected to both?
If so check to see if on both 5Ks you have same configuration for each port.
If you could provide the sh run that will be helpful as well.
12-27-2012 04:24 AM
Hi Senthilkumar
sequence of messages:
means that your fex just came online, and all ports are down yet.
If you see that your fex flaps too often please check powersupplies on it, also check fabric links.
HTH,
Alex
01-15-2013 10:02 PM
Hi Alex,
Thanks for your reply, We are getting same error logs on other switch like fex 121 online
Checked power supply status all everything fine.
Please give some idea to resolve this issue.
01-16-2013 03:55 AM
Hi Senthilkumar
Can you please post lost that repeats. Especially errors.
Last logs that were added just shows that FEX comes online.
01-16-2013 07:38 PM
We are getting some error logs like below everyday.
Switch Details : Nexus 5K .
Logs:
2013 Jan 16 10:31:15 NX5K %ETHPORT-5-IF_DOWN_ADMIN_DOWN: Interface Ethernet121/1/44 is down (Administratively down)
2013 Jan 16 10:31:15 NX5K %ETHPORT-5-IF_DOWN_ADMIN_DOWN: Interface Ethernet121/1/45 is down (Administratively down)
2013 Jan 16 10:31:15 NX5K %ETHPORT-5-IF_DOWN_ADMIN_DOWN: Interface Ethernet121/1/46 is down (Administratively down)
2013 Jan 16 10:31:15 NX5K %ETHPORT-5-IF_DOWN_ADMIN_DOWN: Interface Ethernet121/1/47 is down (Administratively down)
2013 Jan 16 10:31:15 NX5K %ETHPORT-5-IF_DOWN_ADMIN_DOWN: Interface Ethernet121/1/48 is down (Administratively down)
2013 Jan 16 10:31:15 NX5K %PFMA-2-FEX_STATUS: Fex 121 is online
2013 Jan 16 10:31:15 NX5K %NOHMS-2-NOHMS_ENV_FEX_ONLINE: FEX-121 On-line
2013 Jan 16 10:31:16 NX5K %PFMA-2-FEX_STATUS: Fex 121 is online
NX5K# sh fex
FEX FEX FEX FEX
Number Description State Model Serial
121 FEX121 Online N2K-C2248TP-1GE xxxxxxxxx
122 FEX122 Online N2K-C2248TP-1GE xxxxxxxxx
NX5K#
NX5K#
NX5K# sh fex 121
Extender Model: N2K-C2248TP-1GE, Extender Serial: xxxxxxxx
NX5K#
NX5K# sh environment fex 121
Temperature Fex 121:
Module Sensor MajorThresh MinorThres CurTemp Status
(Celsius) (Celsius) (Celsius)
1 Outlet-1 63 45 24 ok
1 Outlet-2 57 45 28 ok
1 Inlet-1 65 55 26 ok
1 Die-1 100 85 36 ok
Fan Fex: 121:
Fan Model Hw Status
Chassis N2K-C2248-FAN -- ok
PS-1 N2200-PAC-400W -- ok
PS-2 N2200-PAC-400W -- ok
Power Supply Fex 121:
Voltage: 12 Volts
PS Model Power Power Status
(Watts) (Amp)
1 N2200-PAC-400W 396.00 33.00 ok
2 N2200-PAC-400W 396.00 33.00 ok
Mod Model Power Power Power Power Status
Requested Requested Allocated Allocated
(Watts) (Amp) (Watts) (Amp)
1 N2K-C2248TP-1GE 58.80 4.90 58.80 4.90 powered-up
Power Usage Summary:
Power Supply redundancy mode: redundant
Total Power Capacity 792.00 W
Power reserved for Supervisor(s) 58.80 W
Power currently used by Modules 0.00 W
Total Power Available 733.20 W
NX5K#
01-16-2013 08:33 PM
Would you post the following:
sh port-channel summary
sh interface port-channel 121
sh interface ethernet1/5
Also how are your FEX's setup? Are you dual homing them between two 5k's are are they singled homed to just one 5k?
01-16-2013 09:22 PM
Thanks Hill,
I have pasted all the requested logs below....
Yes,It's dual homed , we are using for redundancy for another 5K( Two 5k's).
Logs;
NX5K# sh port-channel summary
Flags: D - Down P - Up in port-channel (members)
I - Individual H - Hot-standby (LACP only)
s - Suspended r - Module-removed
S - Switched R - Routed
U - Up (port-channel)
Group Port- Type Protocol Member Ports
Channel
21 Po21(SU) Eth LACP Eth1/1(P) Eth1/2(P)
121 Po121(SU) Eth NONE Eth1/5(P)
122 Po122(SU) Eth NONE Eth1/6(P)
200 Po200(SU) Eth LACP Eth1/3(P) Eth1/4(P)
NX5K#
NX5K#
NX5K# sh int port-channel 121
port-channel121 is up
vPC Status: Up, vPC number: 121
Hardware: Port-Channel, address: xxxxxxxxx
Description: VPC Etherchannel to Nexus2K
MTU 1500 bytes, BW 10000000 Kbit, DLY 10 usec,
Encapsulation ARPA
Port mode is fex-fabric
full-duplex, 10 Gb/s
Beacon is turned off
Input flow-control is off, output flow-control is off
Switchport monitor is off
EtherType is 0x8100
Members in this channel: Eth1/5
30 seconds input rate 25344 bits/sec, 3168 bytes/sec, 1 packets/sec
30 seconds output rate 2352 bits/sec, 294 bytes/sec, 1 packets/sec
Load-Interval #2: 5 minute (300 seconds)
input rate 23.13 Kbps, 2 pps; output rate 2.20 Kbps, 1 pps
RX
65742824 unicast packets 6938469 multicast packets 15067 broadcast packets
72696360 input packets 72368121160 bytes
39108278 jumbo packets 0 storm suppression bytes
0 runts 0 giants 0 CRC 0 no buffer
0 input error 0 short frame 0 overrun 0 underrun 0 ignored
0 watchdog 0 bad etype drop 0 bad proto drop 0 if down drop
0 input with dribble 0 input discard
0 Rx pause
TX
26659449 unicast packets 7045536 multicast packets 257 broadcast packets
33705242 output packets 7222924904 bytes
0 jumbo packets
0 output errors 0 collision 0 deferred 0 late collision
0 lost carrier 0 no carrier 0 babble
0 Tx pause
618 interface resets
NX5K#
NX5K# sh interface ethernet 1/5
Ethernet1/5 is up
Hardware: 1000/10000 Ethernet, address: xxxxxxxxxx
Description: Nexus 2K - NOKCPXX-NX2K021
Encapsulation ARPA
full-duplex, 10 Gb/s, media type is 10G
Rate mode is dedicated
EtherType is 0x8100
Last link flapped 12:47:36
30 seconds input rate 34408 bits/sec, 4301 bytes/sec, 1 packets/sec
30 seconds output rate 2808 bits/sec, 351 bytes/sec, 1 packets/sec
input rate 34.60 Kbps, 3 pps; output rate 2.28 Kbps, 1 pps
RX
65742868 unicast packets 6938472 multicast packets 15067 broadcast packets
72696407 input packets 72368173376 bytes
39108308 jumbo packets 0 storm suppression bytes
0 Rx pause
TX
26659463 unicast packets 7045539 multicast packets 257 broadcast packets
33705259 output packets 7222928160 bytes
0 jumbo packets
0 Tx pause
NX5K#
01-16-2013 09:28 PM
When i checked " sh fex details" it's showing below logs for fex 121.
Eth121/1/44 Down None
Eth121/1/45 Down None
Eth121/1/46 Down None
Eth121/1/47 Down Po121
Eth121/1/48 Down Po121
Logs:
01/14/2013 15:11:51.617771: Module Online
01/14/2013 15:30:27.56599: Deleting route to FEX
01/14/2013 15:30:27.61663: Module disconnected
01/14/2013 15:30:27.62860: Offlining Module
01/14/2013 15:30:27.63524: Module Offline Sequence
01/14/2013 15:30:27.759237: Module Offline
01/14/2013 15:31:04.57251: Module register received
01/14/2013 15:31:04.63233: Registration response sent
01/14/2013 15:31:04.180789: Module Online Sequence
01/14/2013 15:31:06.304134: Module Online
01/15/2013 01:00:17.660104: Deleting route to FEX
01/15/2013 01:00:17.669093: Module disconnected
01/15/2013 01:00:17.670332: Offlining Module
01/15/2013 01:00:17.671002: Module Offline Sequence
01/15/2013 01:00:18.228589: Module Offline
01/15/2013 01:00:54.263629: Module register received
01/15/2013 01:00:54.269597: Registration response sent
01/15/2013 01:00:54.386993: Module Online Sequence
01/15/2013 01:00:56.645328: Module Online
01/15/2013 01:24:52.156439: Deleting route to FEX
01/15/2013 01:24:52.162223: Module disconnected
01/15/2013 01:24:52.163448: Offlining Module
01/15/2013 01:24:52.164126: Module Offline Sequence
01/15/2013 01:24:52.783929: Module Offline
01/15/2013 01:25:28.7248: Module register received
01/15/2013 01:25:28.13484: Registration response sent
01/15/2013 01:25:28.127899: Module Online Sequence
01/15/2013 01:25:30.368767: Module Online
01/15/2013 05:20:57.985081: Deleting route to FEX
01/15/2013 05:20:57.990061: Module disconnected
01/15/2013 05:20:57.991068: Offlining Module
01/15/2013 05:20:57.991751: Module Offline Sequence
01/15/2013 05:20:58.557559: Module Offline
01/15/2013 05:21:35.214382: Module register received
01/15/2013 05:21:35.220519: Registration response sent
01/15/2013 05:21:35.336923: Module Online Sequence
01/15/2013 05:21:37.497165: Module Online
01/15/2013 07:13:48.753789: Deleting route to FEX
01/15/2013 07:13:48.759098: Module disconnected
01/15/2013 07:13:48.760342: Offlining Module
01/15/2013 07:13:48.761069: Module Offline Sequence
01/15/2013 07:13:49.357563: Module Offline
01/15/2013 07:14:26.204863: Module register received
01/15/2013 07:14:26.210923: Registration response sent
01/15/2013 07:14:26.327326: Module Online Sequence
01/15/2013 07:14:28.444356: Module Online
01/15/2013 07:29:58.703190: Deleting route to FEX
01/15/2013 07:29:58.710180: Module disconnected
01/15/2013 07:29:58.711436: Offlining Module
01/15/2013 07:29:58.712116: Module Offline Sequence
01/15/2013 07:29:59.289830: Module Offline
01/15/2013 07:30:34.551855: Module register received
01/15/2013 07:30:34.557942: Registration response sent
01/15/2013 07:30:34.672304: Module Online Sequence
01/15/2013 07:30:36.831234: Module Online
01/16/2013 10:30:38.388497: Deleting route to FEX
01/16/2013 10:30:38.394546: Module disconnected
01/16/2013 10:30:38.395790: Offlining Module
01/16/2013 10:30:38.396473: Module Offline Sequence
01/16/2013 10:30:38.990842: Module Offline
01/16/2013 10:31:13.90472: Module register received
01/16/2013 10:31:13.96516: Registration response sent
01/16/2013 10:31:13.214606: Module Online Sequence
01/16/2013 10:31:15.813230: Module Online
Thanks....
01-17-2013 06:15 AM
Okay. From all your logs it looks like this is only happening to FEX 121. Is that correct or is this happening to other FEX's as well.
I should have been more specific. From both 5k's post:
sh running interface ethernet 1/5 (just to verify configs match from both sides)
I want to know if the FEX is losing connectivity to both or just one 5k. Also is UDLD configured on those interfaces?
sh udld ethernet 1/5
01-17-2013 09:00 PM
Thanks for update....
This one only happening on one switch only another switch is working fine.
Logs for another switch:
NX5K# sh interface port-channel 121
Hardware: Port-Channel, address: xxxxxxxxxxxx
Encapsulation ARPA
EtherType is 0x8100
30 seconds input rate 34664 bits/sec, 4333 bytes/sec, 3 packets/sec
30 seconds output rate 2776 bits/sec, 347 bytes/sec, 1 packets/sec
input rate 23.98 Kbps, 2 pps; output rate 2.25 Kbps, 1 pps
RX
53867785 unicast packets 5689200 multicast packets 1 broadcast packets
59556986 input packets 59357255207 bytes
32093532 jumbo packets 0 storm suppression bytes
0 Rx pause
TX
21774939 unicast packets 5781625 multicast packets 6 broadcast packets
27556570 output packets 5850375464 bytes
0 jumbo packets
0 Tx pause
1 interface resets
NX5K# sh interface ethernet1/5
Ethernet1/5 is up
Hardware: 1000/10000 Ethernet, address: xxxxxxxxxxxx
Encapsulation ARPA
EtherType is 0x8100
Last link flapped 29week(s) 3day(s)
30 seconds input rate 27776 bits/sec, 3472 bytes/sec, 2 packets/sec
30 seconds output rate 2648 bits/sec, 331 bytes/sec, 0 packets/sec
input rate 22.59 Kbps, 2 pps; output rate 2.25 Kbps, 1 pps
RX
53867829 unicast packets 5689203 multicast packets 1 broadcast packets
59557033 input packets 59357307423 bytes
32093562 jumbo packets 0 storm suppression bytes
0 Rx pause
TX
21774953 unicast packets 5781628 multicast packets 6 broadcast packets
27556587 output packets 5850378720 bytes
0 jumbo packets
0 Tx pause
1 interface resets
NX5K# sh running interface ethernet 1/5
!Command: show running-config interface Ethernet1/5
!Time: Thu Jan 17 22:55:39 2013
version 5.0(3)N1(1c)
description Nexus 2K - NOKCPXX-NX2K021
switchport mode fex-fabric
fex associate 121
channel-group 121
no shutdown
NX5K#
Sen
01-18-2013 06:22 AM
Sen,
I would start with first placing your SFP modules between the troubled 5k and 2k. If the interfaces continues to reset I would then replace the fiber cable between the two. After these steps post back if the issue is not resolved.
01-18-2013 07:13 AM
Sorry, You mean the Uplink cable between 2k and 5k is it?......
Thanks.....
Sen
01-18-2013 07:16 AM
Yes the uplink cable and the SFP module (transceiver) the cable plugs into.
01-18-2013 08:11 AM
Thanks for reply..........
Please let me know how to check the redundancy on the uplink?.
We want to change the cable now how to switchover all the traffic to other switch?...
Please let me know the steps ASAP.
Sen
