Join Customer Connection to register!
430
Highlighted
Nexus 5k fail over problem
Hi I have implemented nexus5k on failover ,when am doing testing am facing this pblm,
1.core 1 is up core2 is down everything is working fine.
2.core2 is up core 1 is down nothing is working.
Kindly find the attached logs
=~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2012.09.05 13:39:01 =~=~=~=~=~=~=~=~=~=~=~=
!Command: show running-config
!Time: Thu Apr  2 08:08:42 2009
version 5.1(3)N1(1a)
hostname Core1
feature telnet
no feature http-server
cfs eth distribute
feature interface-vlan
feature hsrp
feature lacp
feature vpc
feature lldp
feature fex
username admin password 5 $1$VYgbo.p4$tpYWJXRxnU0rXPjC3.ahf/  role network-admin
no password strength-check
banner motd #Nexus 5000 Switch
[7m--More-- [m
ip domain-lookup
logging event link-status default
class-map type qos class-fcoe
class-map type queuing class-fcoe
  match qos-group 1
class-map type queuing class-all-flood
  match qos-group 2
class-map type queuing class-ip-multicast
  match qos-group 2
class-map type network-qos class-fcoe
  match qos-group 1
class-map type network-qos class-all-flood
  match qos-group 2
class-map type network-qos class-ip-multicast
  match qos-group 2
fex 100
  pinning max-links 1
  description "***FEX-100***"
fex 101
  pinning max-links 1
  description "***FEX-101***"
snmp-server user admin network-admin auth md5 0xaa5136677da0ef92b258b8815d9efeef
priv 0xaa5136677da0ef92b258b8815d9efeef localizedkey
[7m--More-- [m
[K
vrf context management
vlan 1
vlan 2
  name server
vlan 3
  name ILO
vlan 4
  name clusters
vlan 5
  name Inside
vlan 7
  name 10GFiber
vlan 10
vpc domain 10
  role priority 90
  peer-keepalive destination 1.1.1.1
  peer-config-check-bypass
interface Vlan1
interface Vlan2
  no shutdown
[7m--More-- [m
  description ***Server***
  ip address x.x.x.x24
  hsrp 1
    preempt
    priority 120
    ip x.x.x.x
interface Vlan3
  no shutdown
  ip address x.x.x.x/24
  hsrp 1
    preempt
    priority 120
    ip x.x.x.x
interface Vlan5
  no shutdown
  ip address x.x.x.x/29
  hsrp 1
    preempt
    priority 120
    ip x.x.x.x
interface Vlan7
  no shutdown
  description ***10-G-Fiber***
  hsrp 1
    preempt
    priority 120
    ip x.x.x.x
interface Vlan10
  no shutdown
  hsrp 1
    preempt
    priority 120
    ip x.x.x.x
interface port-channel10
  switchport mode trunk
  spanning-tree port type network
  vpc peer-link
interface port-channel100
[7m--More-- [m
  switchport mode fex-fabric
  fex associate 100
  vpc 100
interface port-channel101
  fex associate 101
  vpc 101
interface Ethernet1/1
  switchport access vlan 7
interface Ethernet1/2
interface Ethernet1/3
interface Ethernet1/4
interface Ethernet1/5
[7m--More-- [m
[K
interface Ethernet1/6
interface Ethernet1/7
interface Ethernet1/8
interface Ethernet1/9
interface Ethernet1/10
interface Ethernet1/11
interface Ethernet1/12
interface Ethernet1/13
interface Ethernet1/14
[7m--More-- [m
interface Ethernet1/15
interface Ethernet1/16
interface Ethernet1/17
interface Ethernet1/18
interface Ethernet1/19
interface Ethernet1/20
interface Ethernet1/21
interface Ethernet1/22
interface Ethernet1/23
interface Ethernet1/24
interface Ethernet1/25
interface Ethernet1/26
[7m--More-- [m
[K
interface Ethernet1/27
  no cdp enable
interface Ethernet1/28
  fex associate 101
  channel-group 101
interface Ethernet1/29
  fex associate 100
  channel-group 100
interface Ethernet1/30
  fex associate 101
  channel-group 101
interface Ethernet1/31
  channel-group 10
[7m--More-- [m
interface Ethernet1/32
  channel-group 10
interface mgmt0
  ip address 1.1.1.2/30
  ip directed-broadcast
interface Ethernet100/1/1
  switchport access vlan 2
interface Ethernet100/1/2
interface Ethernet100/1/3
interface Ethernet100/1/4
interface Ethernet100/1/5
interface Ethernet100/1/6
interface Ethernet100/1/7
interface Ethernet100/1/8
interface Ethernet100/1/9
interface Ethernet100/1/10
interface Ethernet100/1/11
interface Ethernet100/1/12
interface Ethernet100/1/13
[7m--More-- [m
[K
interface Ethernet100/1/14
interface Ethernet100/1/15
interface Ethernet100/1/16
interface Ethernet100/1/17
interface Ethernet100/1/18
interface Ethernet100/1/19
interface Ethernet100/1/20
interface Ethernet100/1/21
[7m--More-- [m
interface Ethernet100/1/22
interface Ethernet100/1/23
interface Ethernet100/1/24
interface Ethernet100/1/25
  switchport access vlan 3
interface Ethernet100/1/26
interface Ethernet100/1/27
interface Ethernet100/1/28
interface Ethernet100/1/29
interface Ethernet100/1/30
interface Ethernet100/1/31
interface Ethernet100/1/32
interface Ethernet100/1/33
interface Ethernet100/1/34
interface Ethernet100/1/35
interface Ethernet100/1/36
[7m--More-- [m
[K
interface Ethernet100/1/37
interface Ethernet100/1/38
interface Ethernet100/1/39
interface Ethernet100/1/40
interface Ethernet100/1/41
  switchport access vlan 5
interface Ethernet100/1/42
interface Ethernet100/1/43
interface Ethernet100/1/44
interface Ethernet100/1/45
  switchport access vlan 10
interface Ethernet100/1/46
interface Ethernet100/1/47
interface Ethernet100/1/48
interface Ethernet101/1/1
interface Ethernet101/1/2
interface Ethernet101/1/3
interface Ethernet101/1/4
interface Ethernet101/1/5
interface Ethernet101/1/6
interface Ethernet101/1/7
interface Ethernet101/1/8
interface Ethernet101/1/9
interface Ethernet101/1/10
interface Ethernet101/1/11
[7m--More-- [m
[K
interface Ethernet101/1/12
interface Ethernet101/1/13
interface Ethernet101/1/14
interface Ethernet101/1/15
interface Ethernet101/1/16
interface Ethernet101/1/17
interface Ethernet101/1/18
interface Ethernet101/1/19
[7m--More-- [m
interface Ethernet101/1/20
interface Ethernet101/1/21
interface Ethernet101/1/22
interface Ethernet101/1/23
interface Ethernet101/1/24
interface Ethernet101/1/25
interface Ethernet101/1/26
[7m--More-- [m
interface Ethernet101/1/27
interface Ethernet101/1/28
interface Ethernet101/1/29
interface Ethernet101/1/30
interface Ethernet101/1/31
interface Ethernet101/1/32
interface Ethernet101/1/33
interface Ethernet101/1/34
[7m--More-- [m
[K
interface Ethernet101/1/35
interface Ethernet101/1/36
interface Ethernet101/1/37
interface Ethernet101/1/38
interface Ethernet101/1/39
interface Ethernet101/1/40
interface Ethernet101/1/41
interface Ethernet101/1/42
[7m--More-- [m
interface Ethernet101/1/43
interface Ethernet101/1/44
interface Ethernet101/1/45
interface Ethernet101/1/46
interface Ethernet101/1/47
interface Ethernet101/1/48
line console
line vty
boot kickstart bootflash:/n5000-uk9-kickstart.5.1.3.N1.1a.bin
boot system bootflash:/n5000-uk9.5.1.3.N1.1a.bin
[7m--More-- [m
ip route 0.0.0.0/0 1.1.1.1
ip route 0.0.0.0/0 x.x.x.x
core 2.
=~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2012.09.05 13:39:50 =~=~=~=~=~=~=~=~=~=~=~=
!Time: Thu Apr  2 08:08:33 2009
hostname cisco
feature telnet
cfs eth distribute
feature hsrp
feature lacp
feature vpc
feature lldp
feature fex
username admin password 5 $1$b1lq052j$s8MCuTaAyALON7b9UbOs./  role network-admin
[7m--More-- [m
ip domain-lookup
  match qos-group 1
  match qos-group 2
  match qos-group 2
  match qos-group 1
  match qos-group 2
  match qos-group 2
fex 100
  pinning max-links 1
  description "FEX100"
fex 101
  pinning max-links 1
  description "FEX101"
snmp-server user admin network-admin auth md5 0xc2298dd394351aff99c45e9f81241ba5
priv 0xc2298dd394351aff99c45e9f81241ba5 localizedkey
[7m--More-- [m
[K
vlan 1
vlan 2
  name Server
vlan 3
  name IL0
vlan 4
  name Cluster
vlan 5
  name Inside
vlan 7
  name 10GFiber
vlan 10
  name test
vpc domain 10
  role priority 100
  peer-keepalive destination 1.1.1.2
interface Vlan1
interface Vlan2
[7m--More-- [m
  no shutdown
  description "SERVER"
  hsrp 1
    preempt
    priority 110
    ip x.x.x.x
interface Vlan3
  no shutdown
  hsrp 1
    preempt
    priority 110
    ip x.x.x.x
interface Vlan5
  no shutdown
  hsrp 1
    preempt
    priority 110
    ip x.x.x.x
[7m--More-- [m
[K
interface Vlan7
  no shutdown
  hsrp 1
    preempt
    priority 110
    ip x.x.x.x
interface Vlan10
  no shutdown
  hsrp 1
    preempt
    priority 110
    ip x.x.x.x
  vpc peer-link
[7m--More-- [m
  fex associate 100
  vpc 100
  fex associate 101
  vpc 101
[7m--More-- [m
[7m--More-- [m
[K
[7m--More-- [m
[K
  fex associate 101
  channel-group 101
  fex associate 100
  channel-group 100
  channel-group 10
[7m--More-- [m
  channel-group 10
interface mgmt0
  ip address 1.1.1.1/30
[7m--More-- [m
[7m--More-- [m
[7m--More-- [m
[K
[7m--More-- [m
[7m--More-- [m
[7m--More-- [m
[K
[7m--More-- [m
[7m--More-- [m
[7m--More-- [m
[K
[7m--More-- [m
[7m--More-- [m
[7m--More-- [m
[K
line console
line vty
ip route 0.0.0.0/0 1.1.1.2
[7m--More-- [m
please help on this on urgent basis
0 REPLIES 0
Content for Community-Ad
