Nexus 5k High Fan RPM
The fans 1 & 2 in Module 1 on the Nexus5K are still experiencing the very high RPM and speed issue.
I have replaced the fan from another operational Nexus5K, and the fans are fine in the other Nexus. The replacement fans also have the same issues, so it is not a fan hardware issue.
There are no threshold alarms. the only log entry that is related to this is as follows:
%NOHMS-2-NOHMS_ENV_ERR_FAN_SPEED: System minor alarm in fan tray 1: fan speed is out of range on fan 1. 7950 to 12500 rpm expected.
I have provided the output for both the fan detail and the temperature.
N5K-01# sh environment fan detail
Fan:
Module  Fan  Airflow        Speed(%)  Speed(RPM)
              Direction
1       1    Back-to-Front  60        13881
1       2    Back-to-Front  60        12705
2       1    Back-to-Front  60        8463
2       2    Back-to-Front  60        8477
3       1    Back-to-Front  60        8477
3       2    Back-to-Front  60        8450
4       1    Back-to-Front  60        8385
4       2    Back-to-Front  60        8626
Power Supply:
Module  Airflow        Configured
         Direction      Speed (%)
1       Back-to-Front  100
2       Back-to-Front  100
Temperature
Module   Sensor     MajorThresh   MinorThres   CurTemp     Status
                     (Celsius)     (Celsius)    (Celsius)
1        Outlet     65            55           36          ok
1        PS-1       63            60           30          ok
1        PS-2       63            60           31          ok
Please let me know what can be done. Is that speed within acceptable limit.
Nachi
InayathUlla Sharieff
Usually this error message means that your have fan tray fault.
Is the same fan tray working fine on the other nexus?
Can you try reseating it again? Once you done provide me the following outputs:
show env fan
show en power in
show logging last 100
Inayath
6 Replies 6
show env fan
show en power in
Inayath
Yes, the fan tray works fine on the other nexus switch.
output of requested commands plz?
Thanks Inayathulla. Cisco confirmed that's a faulty hardware and sending a replacement.
hi nachi,ece,
please advise what hardware was replaced, i.e. fan trays or entire chassis etc.
i have a client with exactly the same situation.
thanks.
any additional advise would be appreciated.
Hi Francois,
Replaced the whole switch.
