Hello Cisco community,
My client has two Nexus 5K in VPC mode with switch-profile to sync the configuration.
I want to put in place a backup configuration. To do so I issue the command:
copy run ftp://user@myftp//backup_conf_5k.txt
When I look to the configuration there is some weird stuff:
In global conf I get:
pinning max-links 1
pinning max-links 1
pinning max-links 1
pinning max-links 1
So I am not able to see my Fexs.
But in switch-profile configuration, I get:
fex 301
description "Uplink-FEX301"
fex 302
description "Uplink-FEX302"
fex 303
description "Uplink-FEX303"
fex 304
description "Uplink-FEX304"
It seems that is because some commands can't be put in switch-profile configuration.
Ok, but what's happen when I try to put back my backup configuration to my N5K switch ?
I did a 'copy bootflash:backup_conf_5k.txt run' and I get a lot of errors.
Does somebody know how to restore a backup configuration to my N5K with switch-profile in the configuration ?
Other question:
If I want to remove the switch-profile without loosing any configuration, do you know if the command below works fine and without disruption ?
no switch-profile XX profile-only
Thanks a lot,
Alex
