Nexus 5K vPC and Dropping Connections
Terry MacDougal
We have a pair of 5K's (6.0(2)N1(2)), clients are experiencing slow connectivity and dropped connections at times.
Connected upstream to the 5K is a 4948 (trunking) with only 1 connection to 5k-A. Any ideas to what would be happening? STP maybe??? The vPC looks fine...
sho vpc consistency-parameters int port-channel 1
Note: **** Global type-1 parameters will be displayed for peer-link *****
    Legend:
        Type 1 : vPC will be suspended in case of mismatch
Name                        Type  Local Value            Peer Value
QoS                         2     ([], [], [], [], [],   ([], [], [], [], [],
Network QoS (MTU)           2     (1538, 0, 0, 0, 0, 0)  (1538, 0, 0, 0, 0, 0)
Network Qos (Pause)         2     (F, F, F, F, F, F)     (F, F, F, F, F, F)
Input Queuing (Bandwidth)   2     (100, 0, 0, 0, 0, 0)   (100, 0, 0, 0, 0, 0)
Input Queuing (Absolute     2     (F, F, F, F, F, F)     (F, F, F, F, F, F)
Priority)
Output Queuing (Bandwidth)  2     (100, 0, 0, 0, 0, 0)   (100, 0, 0, 0, 0, 0)
Output Queuing (Absolute    2     (F, F, F, F, F, F)     (F, F, F, F, F, F)
Priority)
STP Mode                    1     Rapid-PVST             Rapid-PVST
STP Disabled                1     None                   None
STP MST Region Name         1     ""                     ""
STP MST Region Revision     1     0                      0
STP MST Region Instance to  1
VLAN Mapping
STP Loopguard               1     Disabled               Disabled
STP Bridge Assurance        1     Enabled                Enabled
STP Port Type, Edge         1     Normal, Disabled,      Normal, Disabled,
BPDUFilter, Edge BPDUGuard        Disabled               Disabled
STP MST Simulate PVST       1     Enabled                Enabled
IGMP Snooping Group-Limit   2     4000                   4000
Allowed VLANs               -     xxx,xxx,xxxx,xxx,xxx,xxx,xxx,xxx
5 Replies 5
Peter Koltl
Level 7
Level 7
Have a look at
show vtp status
on both Nexus'
vtp                   1         disabled
glen.grant
  Do you know the reasoning for making it a vpc if it's single connected to the 4948 ???
Reza Sharifi
Agreed with Glen.  There is no need for vPC, since there is only a single connection to one of the 5ks.
Sorry guys, we have the other switch on order. I just wanted to verify the config as it stands now....
