Showing results forĀ
Search instead forĀ
Did you mean:Ā
Nexus 7000 AAA tacacs+ issue
ckeithjones
Beginner
Beginner
I cannot get the AAA tacacs+ authentication to work on my Nexus 7000. The following is the logging error I get:
2011 Dec  7 01:17:05 MCN-CORE-D-7020 %AUTHPRIV-3-SYSTEM_MSG: pam_aaa:Authentication failed for user ctcrgrf from 172.26.32.200 - sshd[16930]
2011 Dec  7 01:17:05 MCN-CORE-D-7020 %DAEMON-3-SYSTEM_MSG: error: PAM: Authentication failure for illegal user ctcrgrf from 172.26.32.200 - sshd[16922]
2011 Dec  7 01:17:08 MCN-CORE-D-7020 %AUTHPRIV-3-SYSTEM_MSG: pam_aaa:Authentication failed for user ctcrgrf from 172.26.32.200 - sshd[16935]
2011 Dec  7 01:17:08 MCN-CORE-D-7020 %DAEMON-3-SYSTEM_MSG: error: PAM: Authentication failure for illegal user ctcrgrf from 172.26.32.200 - sshd[16922]
2011 Dec  7 01:17:08 MCN-CORE-D-7020 %AUTHPRIV-3-SYSTEM_MSG: pam_aaa:Authentication failed for user ctcrgrf from 172.26.32.200 - sshd[16936]
2011 Dec  7 01:17:42 MCN-CORE-D-7020 %VSHD-5-VSHD_SYSLOG_CONFIG_I: Configured from vty by ncbranch on 172.26.22.20@pts/0
2011 Dec  7 01:19:46 MCN-CORE-D-7020 %VSHD-5-VSHD_SYSLOG_CONFIG_I: Configured from vty by ncbranch on 172.26.22.20@pts/0
2011 Dec  7 01:29:34 MCN-CORE-D-7020 %AUTHPRIV-3-SYSTEM_MSG: pam_aaa:Authentication failed for user ctcrsrackj from 172.26.22.20 - sshd[17316]
2011 Dec  7 01:29:34 MCN-CORE-D-7020 %DAEMON-3-SYSTEM_MSG: error: PAM: Authentication failure for illegal user ctcrsrackj from 172.26.22.20 - sshd[17315]
Relevant config:
MCN-CORE-D-7020# show run tacacs+
!Command: show running-config tacacs+
!Time: Wed Dec  7 01:33:42 2011
version 5.1(3)
feature tacacs+
tacacs-server key 7 "XXXXXXX"
ip tacacs source-interface mgmt0
tacacs-server timeout 60
tacacs-server host 172.26.32.200
tacacs-server host 172.25.35.9
aaa group server tacacs+ tacacs+
    server 172.26.32.200
    server 172.25.35.9
    use-vrf management
All users get this same error when trying to log in. Any other switch works with that username.
Reza Sharifi
Hall of Fame Master Hall of Fame Master
Hall of Fame Master
Can you add this command to you tacacs config and test again?
aaa authentication login default group tacacs+ tacacs+
I forgot to put I originally had that in there. I put it back but I get the same response.
MCN-CORE-D-7020# sh run tacacs+ all
!Command: show running-config tacacs+ all
!Time: Wed Dec  7 13:21:47 2011
version 5.1(3)
feature tacacs+
tacacs-server key 7 "XXXXXXXXX"
tacacs-server test username test password test idle-time 0
tacacs-server deadtime 0
tacacs-server host 172.26.32.200 port 49
tacacs-server host 172.25.35.9 port 49
tacacs-server host 172.26.32.200 test username test password test idle-time 0
tacacs-server host 172.25.35.9 test username test password test idle-time 0
    server 172.25.35.9
    use-vrf management
MCN-CORE-D-7020# sh run aaa
!Command: show running-config aaa
!Time: Wed Dec  7 13:21:54 2011
version 5.1(3)
tacacs-server directed-request
Keith
Hi All,
I“ve the same logging errors on my N7K. Have you found the problem and can you tell me a solution.
Many thanks !!!!
br
Jens
No, I have a TAC case open on it. So far it seems it's a problem with the freeware (TacPlus) software my company is using to do AAA.
Keith
Recognize Your Peers
