nexus 7000 add vlan to trunk interface
Hasrat Raja
trying to add vlan to trunk interface, it gives following error
nexus(config-if)# interface Ethernet6/18
nexus(config-if)#  switchport trunk allowed vlan add 120
interface has multiple vlans, if I do a question mark after switchport it only gives host option
nexus(config-if)# switchport ?
  host  Set port host
please let know what is needed to add vlan.
thanks
ok, this interface is part of portchannel 11.
try this:
interface port-channel 11
8 Replies 8
Reza Sharifi
Can you post the output of "sh run int e6/18"?
Here is it
  switchport
  switchport mode trunk
  switchport trunk allowed vlan 1,6,9-12,14,27,35,82,87,93,125,130-131
  switchport trunk allowed vlan add 134,187,254-255,316-320,415,451
  switchport trunk allowed vlan add 453,455,500,2049,2051
  storm-control broadcast level 1
  channel-group 11
  no shutdown
thanks
try this:
Reza,
tried this and it is showing under interface, but interface doesn't sow under 'sh vlan", only port channel shows up, if there is no port channel then the command will work ?
thanks
That is correct.  When the physical interfaces are part of a Portchannel, you add the config to the Portchannel and the physical interfaces inherent the config change.
When the interface is not part of a Portchannel then you can add the command directly to the interface
Thank you for the explanation, is it normal that physical interface is not showing under sh vlan ? I see some interfaces which are part of port channels
When you issue "sh vlan" it should show both the Portchannel ID and the physical interfaces. For example in below config interface e1/7/1 is part of po5
20   VLAN0020                         active    Po2, Po3, Po4, Po5, Po6, Po7
                                                Po10, Eth1/7/1, Eth1/7/2
Can you post the output of "sh vlan id 120"
it doesn't show:
nexus# sh vlan id 120
VLAN Name                             Status    Ports
120  private_network                active    Po10, Po11, Po1093, Po1098
VLAN Type
120  enet
Remote SPAN VLAN
Disabled
Primary  Secondary  Type             Ports
nexus#
