05-18-2010 12:19 PM - edited 03-06-2019 11:09 AM
Planning an install with Nexus 7000 chassis on a 4-post rack. However, may need to mount the chassis jutting off the front rails.
Does anyone have information on the positions I can change the mounting bracket rails on the chassis to? 3 inches back? 6 inches back? Centered?
Installation manuals only hint at the possibility and shows the chassis riddled with screw holes.
Thanks.
05-18-2010 10:24 PM
Installation manuals only hint at the possibility and shows the chassis riddled with ***** holes.
Thanks.
Check out the below link for more information
Hope to Help !!
Ganesh.H
05-19-2010 06:39 AM
Thanks, but please see this:
Note item #4 rack mounting bracket. I would like to know if these can be shifted back. The dots along the side of the chassis seem to indicate that there are screw holes to allow just that. However, without a physical device on hand, how can I determine how deep these offset positions are?
There are no details on this in that document.
Ed Chu
