Hi *,
in reference to this the following guide, i'd like to identify the Asic-ID, to plan the integration of a FEX 2248PQ to an F2 module interoperated in an F2e M1-xl context-type.
There is a note in the topic "Associating a Fabric Extender to an F2-Series Module"
Each port in the ASIC has an index. Allow only ports with similar indices across ASICs to be added to a port channel.
For example, if port 1 has an index of 1 and port 2 has an index of 2, the following ports are supported and not supported:
A set of ports from an ASIC that has an index sub-set S, such as {1,2,4}, is allowed to be added to a port channel only if the port channel has an equivalent or an empty set.
So is there a way to get the asic-id as mentioned above with some appropriate show commands?
Please be adviced that the FEX are not installed yet.
I need to check beforehand if the cabling is correct.
Some helpful answers within the next few day would be very appreciated.
Thank you in advance
Sven
Solved! Go to Solution.
Sven
Have a look at this article and hopefully it will answer your questions -
http://www.netcraftsmen.net/blogs/entry/using-fex-with-the-f2-card-in-a-nexus-7000.html
Jon
The link from Jon is exactly what you need, but as an additional note, you can determine the port-grouping of any Nexus 7000 I/O module with the show interface ethernet
Towards the end of the output you'll see "Port Group Members" listed which is a list of the ports that are part of the same group as the interface you entered with slot/port.
Sven
Jon
Am I missing something here? Which is very possible. Would it not be easier to just look at the Carmel ASIC info to see what interfaces are mapped to what ASIC?
sh hardware internal carmel all
Well "show hardware internal carmel all" doesn't seem to be supported on an n7k. I've tried it on m1xl and f2 context-types...no luck at all.
I only saw that inside the n5k documentation
Well let me remove foot here. Been a bit since I was in a 7k. Didn't realize that command was not supported there.
That's correct. The Carmel ASIC is the port-controller (UPC) on the Nexus 5500 series switches. The Nexus 7000 F2 cards use Clipper, Eureka and Naxos.
Hi Jon
Hi Steve,
thank you for your quick responses.
I just wanted to make sure, using an apropriate show command, that the "so called" asic-id are not random/weird assigned.
That link was very helpful and well explained.
Basically I'd hoped that Cisco would be a bit more specific about that note ;-)
Best regards
