Nexus 7000 Scheduler Failed (75)
ibasuki
Hi All,
I want to create a scheduler to Cisco Nexus 7000, but I found several problem:
1. Last Execution Status = Failed (75). Anyone know what Failed (75) means? I can't find it anywhere.
Schedule Name : trial-job
User Name : pamadmin
Schedule Type : Run every 0 Days 12 Hrs 0 Mins
Start Time : Fri Sep 23 15:04:25 2022
Last Execution Time : Fri Sep 23 15:04:25 2022
Last Completion Time: Fri Sep 23 15:04:25 2022
Execution count : 1
Job Name Last Execution Status
change-desc Failed (75)
2. There is no output when I push command : sh scheduler logfile. Even after I increase logfile size to 1024.
Here is details of our nexus:
cisco Nexus7000 C7010 (10 Slot) Chassis ("Supervisor Module-2")
System version: 7.3(4)D1(1)
Thank you for your help.
balaji.bandi
Can you post the content of scheduler, what you are trying to achieve ?
BB
Sorry, forgot to input scheduler configuration:
scheduler logfile size 1024
scheduler job name change-desc
configure terminal
interface Ethernet4/44
description BERHASIL CRONJOB
scheduler schedule name trial-job
time daily 11:14
as per i know generally use schedular to backup the config.
for this rquirement i suggest to use EEM script to run that time.
BB
Hey Everyone
I 've the same Error Code
2023 Feb 13 09:30:02.649 N7K-I-DVV-CAMPUS-I %SCHEDULER-3-SCH_ERR: Job Backup for schedule Schedule_Backup failed (75).
Here's the config
config terminal
scheduler aaa-authentication username xxxxxxx password xxxxxx
end
config terminal
scheduler job name Backup
cli var name copy running-config tftp://1.1.1.1 /$(SWITCHNAME)_RunningConfig_$(TIMESTAMP) vrf management
end
config terminal
scheduler schedule name Schedule_Backup
time weekly 02:17:00
job name Backup
end
But, Even if i Execute just  the command
The Backup is Succesful, so the string is ok! but the job doesn't work.
Anyone can help me, Please!
