Join Customer Connection to register!
9069
fhoban
Beginner
Nexus 7000 Span Limitation
Hi All,
I've learned recently that the Nexus 7000 only allows the configuration of a maximum of 2 Monitor sessions for spanning traffic. I only have one monitor session left and I need to do the following. 2 Core Nexus 7000 boxes with 2 different traffic probes/sniffers to each nexus( eg Sniffer 1 connects to Switch A on interface eth 1 and to Switch B on eth 1 ; Sniffer 2 connects to Switch A on eth 2 and to Switch B on eth 2.) My plan was to setup a standard session with multiple sources and destinations then on the interfaces connecting to the sniffers run a trunk and do 'sw trunk allowed xxxxx' and filter what I need to go to each sniffer box. However I've recently found out that some of my source traffic is coming from Port-Channel interfaces.
Is there a way I can get around this and still do the filtering within only 1 monitor session ?
Thanks in advance,
Frank
1 REPLY 1
csarto
Beginner
As stated from this documentation http://docwiki.cisco.com/wiki/Cisco_NX-OS/IOS_SPAN_Comparison :
A single SPAN session can include mixed sources (Ethernet ports, Ethernet Port-Channels, RSPAN sources, VLANs, and the CPU control-plane interface).
128 source interfaces can be configured per session.
32 source VLANs can be configured per session.
32 destination interfaces can be configured per session.
A destination interface can be configured in switchport access or switchport trunk mode. (Trunk mode allows you to tag traffic toward a destination or to perform destination VLAN filtering.)
So I can suppose that with right filters your implementation can be done.
The only caveats/clarifications:
- is your etherchannel a trunk and some vlans go to sniffer 1 and others go to sniffer 2 ?
