Join Customer Connection to register!
320
tsgruu2000
Beginner
Nexus 7000 Transparent Firewall between VRFs
I am trying to connect a transparent firewall to a N7k. Therefore I set up two interfaces E1/17 and E1/18 belonging to different vrf's and connected these ports together. I expected the interfaces would be able to reach each other. Unfortunately this does not work. Is my design supported or do I have to use a seperate VDC for this to work? I'd appreciate a hint for a solution.
Many Thanks,
Urs
2 REPLIES 2
balaji.bandi
VIP Expert
When you mention different VRF, they are different network right.
in most cases Transparent means extend the L2 with FW capabilities, what the use case yours ?
BB
*** Rate All Helpful Responses ***
The goal ist to build a fusion vrf. In the end each vrf peers with the fusion vrf through the transparent firewall. But first I wanted to test connectivity between the vrfs. Unfortunately I cannot reach the interface "behind" the firewall.
