Nexus 7000 VRRP issue
I need some help about a VRRP issue on two nexus 7000.
Vlan test:
Nexus 1:
interface Vlan242
  no ip redirects
  ip address 10.xx.xxx.xx/xx
  no ipv6 redirects
  no shutdown
  vrrp 56
    priority 110
    no shutdown
      Interface  VR IpVersion Pri   Time Pre State   VR IP addr
        Vlan242  56   IPV4    110    1 s  Y  Master 10.xx.xxx.xx
Nexus 2:
interface Vlan242
  no shutdown
  no ip redirects
  no ipv6 redirects
  vrrp 56
    priority 90
    no shutdown
        Vlan242  56   IPV4     90    1 s  Y  Backup 10.xx.xxx.xx
Test:
When I shut the interface vlan 242 on the Nexus 1(10.xx.xxx.xx), I can't ping the interface vlan on the Nexus 2 (10.xx.xxx.xx) and the VRRP (10.xx.xxx.xx) anymore.
On Nexus 1:
        Vlan242  56   IPV4    110    1 s  Y    Init 10.xx.xxx.xx
Vlan242 - Group 56 (IPV4)
     State is Init(Interface down)
     Virtual IP address is 10.xx.xxx.xx
     Priority 110, Configured 110
     Forwarding threshold(for VPC), lower: 1 upper: 110
     Advertisement interval 1
     Preemption enabled
     Virtual MAC address is 0000.xxxx.xxxx
     Master router is Unknown
On Nexus 2:
        Vlan242  56   IPV4     90    1 s  Y  Master 10.xx.xxx.xx
     State is Master
     Priority 90, Configured 90
     Forwarding threshold(for VPC), lower: 1 upper: 90
     Preemption enabled
     Master router is Local
Logs:
 %ARP-3-DUP_VIRT_SRC_IP:  arp [3882]  Source address of packet received from 0000.xxxx.xxxx on Vlan242(port-channel1) is duplicate of local virtual ip, 10.xx.xxx.xx
Thanks for your help.
Francois
Nobody to help me?
Is vlan 242 in the vPC peer link? if not the HSRP peers can't each other.
Ivan_Ypes
I have a similar problem, In your case, the vlan 242 is a vPC VLAN?
Yes, was a vPC VLAN and is on the peer-link. Now we separate the Routing and the DIstribution in diferents VDC and upgrade to vrrp v3 and is solved. But we dont have good experience with vPC+ VRRP.
