Highlighted
Frequent Contributor
Nexus 7009 can ping Hostname but not Telnet
      Just installing my first Nexus 7009, come across a minor problem when trying to telnet from the Nexus
can ping a hostname ok but can't telnet hostname, but ok if I use the IP address ,  see output below
ping Hostname
Using IP address of interface loopback0
PING Hostname.xxxx.com.au (172.17.140.1): 56 data bytes
64 bytes from 172.17.140.1: icmp_seq=0 ttl=250 time=23.185 ms
64 bytes from 172.17.140.1: icmp_seq=1 ttl=250 time=23.196 ms
64 bytes from 172.17.140.1: icmp_seq=2 ttl=250 time=23.106 ms
64 bytes from 172.17.140.1: icmp_seq=3 ttl=250 time=23.018 ms
64 bytes from 172.17.140.1: icmp_seq=4 ttl=250 time=23.086 ms
--- Hostname.xxxx.com.au ping statistics ---
5 packets transmitted, 5 packets received, 0.00% packet loss
round-trip min/avg/max = 23.018/23.118/23.196 ms
telnet Hostname
telnet: Invalid host/interface Hostname.
telnet 172.17.140.1
Trying 172.17.140.1...
Connected to 172.17.140.1.
Escape character is '^]'.
username:
any ideas?
5 REPLIES 5
Highlighted
Beginner
Hi there,
What is the version you are using? I can be https://tools.cisco.com/bugsearch/bug/CSCtq91381.
Madhu
Highlighted
Advisor
     You would have to have the 7000 setup to point to a dns server otherwise there is no way to translate the server name . Search on setting up a ip domain name lookup on a  7000.
Highlighted
Beginner
My assumption was when he tried to ping using host name it translated fine but just that the telnet was not working
Sent from Cisco Technical Support Android App
Highlighted
Madhu,
Your assumptions are correct, I can ping the Hostname but not Telnet to the Hostname, I can telnet to the IP address
I am running System Version: 6.2(2) in the bug you referenced it only mentions version 5  OS, so I wonder if it has not been fixed in release 6 OS
regards
Richard
Highlighted
  You are right.  It wouldn't be the first time they reintroduced a bug in a later release.
Content for Community-Ad
