01-27-2015 05:55 AM - edited 03-07-2019 10:24 PM
I am experiencing a strange behaviour in configuring a 40GigE Link between two Nexus 7009 Eth6/1 and Eth9/2; both sides have a
N7K-M2206FQ-23L Module; I am using a QSFP-40GE-LR4 Optic on both sides. The Operting system is 6.2(6) on both sides.
After configuring the Interfaces as a Layer3 Interface and a no shutdown I get the message
Ethernet6/1 is down (Administratively down)
admin state is down, Dedicated Interface
So what is going wrong ?
Thanks in advance
Manfred
Ethernet6/1 transceiver is present type is QSFP-40GE-LR4 name is CISCO part number is FTL4C1QE1C-C1 revision is B serial number is FNS18410KXL nominal bitrate is 10300 MBit/sec per channel Link length supported for 9/125um fiber is 10 km cisco id is -- cisco extended id number is 176 cisco part number is 10-2848-01 cisco product id is QSFP-40GE-LR4 cisco vendor id is V01
Ethernet9/2 transceiver is present type is QSFP-40GE-LR4 name is CISCO part number is FTL4C1QE1C-C1 revision is B serial number is FNS1834014K nominal bitrate is 10300 MBit/sec per channel Link length supported for 9/125um fiber is 10 km cisco id is -- cisco extended id number is 176
03-05-2015 11:03 AM
can you please share the config
03-05-2015 12:12 PM
After connecting the cable to both ports, do you see green lights on the ports?
Do the interfaces go to up and up mode at all?
