Nexus 7010 port-channel failed, not receiving any LACP BPDUs
hairul_cisco
Hi every one,
I'm having issue when trying to form LACP etherchannel links between N7k and server. Here's the setup:
SERVER eth0-------N7K-1 Eth102/1/9
SERVER eth1-------N7K-2 Eth102/1/9
Configuration:
N7K-1# sh run int eth102/1/9
interface Ethernet102/1/9
  switchport
  switchport access vlan 204
  channel-group 321
  no shutdown
N7K-1# sh run int po321
interface port-channel321
  switchport
  flowcontrol send on
  vpc 321
N7K-2# sh run int eth102/1/9
  switchport
  channel-group 321
  no shutdown
N7K-2# sh run int po321
  switchport
  flowcontrol send on
  vpc 321
vPC status
id   Port   Status Consistency Reason                     Active vlans
321  Po321  up     success     success                    204
Scenario 1-Etherchannel only without protocol
Both links are up, problem only happened when link to N7K-2 restart. If link to N7K-1 restart no problem.
Scenario 2-Etherchannel with LACP
Both physical links NOT up. Logs showing this:
2013 Aug 20 17:04:31 N7K-1 %ETHPORT-5-IF_DOWN_ADMIN_DOWN: Interface Ethernet102/1/9 is down (Administratively down)
2013 Aug 20 17:04:32 N7K-1 %ETHPORT-5-IF_ADMIN_UP: Interface Ethernet102/1/9 is admin up .
2013 Aug 20 17:04:35 N7K-1 %ETHPORT-5-SPEED: Interface Ethernet102/1/9, operational speed changed to 1 Gbps
2013 Aug 20 17:04:35 N7K-1 %ETHPORT-5-IF_DUPLEX: Interface Ethernet102/1/9, operational duplex mode changed to Full
2013 Aug 20 17:04:35 N7K-1 %ETHPORT-5-IF_RX_FLOW_CONTROL: Interface Ethernet102/1/9, operational Receive Flow Control state changed to off
2013 Aug 20 17:04:35 N7K-1 %ETHPORT-5-IF_TX_FLOW_CONTROL: Interface Ethernet102/1/9, operational Transmit Flow Control state changed to on
2013 Aug 20 17:04:35 N7K-1 %ETHPORT-5-SPEED: Interface port-channel321, operational speed changed to 1 Gbps
2013 Aug 20 17:04:35 N7K-1 %ETHPORT-5-IF_DUPLEX: Interface port-channel321, operational duplex mode changed to Full
2013 Aug 20 17:04:35 N7K-1 %ETHPORT-5-IF_RX_FLOW_CONTROL: Interface port-channel321, operational Receive Flow Control state changed to off
2013 Aug 20 17:04:35 N7K-1 %ETHPORT-5-IF_TX_FLOW_CONTROL: Interface port-channel321, operational Transmit Flow Control state changed to on
2013 Aug 20 17:04:55 N7K-1 %ETH_PORT_CHANNEL-5-PORT_SUSPENDED: Ethernet102/1/9: Ethernet102/1/9 is suspended
2013 Aug 20 17:05:13 N7K-1 %LACP-FEX102-5-LACP_SUSPEND_INDIVIDUAL: LACP port Ethernet102/1/9(0x1f650200) of port-channel port-channel321(0x16000140) not receiving any LACP BPDUs  suspending (individual) port
Scenario 3-Etherchannel with LACP to single 3750 switch
All working fine, fail over success as expected.
N7k is using NX-OS 6.0(4)
Anyone facing this issue?
9 Replies 9
hairul_cisco
Note: configuration on nexus with lacp mode, channel-group 321 mode active
As for now, only static etherchannel is "usable"
Sent from Cisco Technical Support Android App
Lei Tian
How is the teaming configured on the server side? Is LACP enabled?
HTH,
Lei Tian
On the server side, bonding is configured with lacp (mode 4, 802.3ad). Test on the scenario 3 (LACP etherchannel to single 3750 switch) confirmed server is configured correctly. Is there any limitation on LACP in N2k?
Does it work with LACP from cisco switch to FEX? You need enable bpdufilter on the switch port for that test. LACP from FEX to pair N7K is supported, but it could be a bug in 6.0 code. Please open a case with TAC to troubleshoot further.
HTH,
Lei Tian
Hi Lei Tian,
I'm working with TAC engineer now. Apparently N7K still not receiving any LACP BPDU even from switch (switch with bpdufilter enable). Will share for any findings.
hairul_cisco
Issues happened due to bug CSCty99763
I had had this problem before.
Please, put the following command, if in your server side is using LACP:
  switchport
  no shutdown
  switchport
  flowcontrol send on
  vpc 321
  switchport
  no shutdown
  switchport
  flowcontrol send on
  vpc 321
Please refer to my 2nd post on Aug 20, 2013
Upgraded to 6.2(2) and solved the problem.
We are seeing some very similar issues. We are connecting an HP DL380 g8 server to a CISCO 2000 FEX which goes back to a NX 7000.  When we connect through to a 5000 it works.
Even outside of LACP connection, a single connection port won't pass VLAN traffic for us either. VMs can not ping through.
VMware has given us a clean bill of health.
We have opened a TAC case with CISCO and he tech doesn't think our nxos version is affected 6.1[4].
We have tried the 'workaround' with no success.
We have also reviewed (admittedly not completely thoroough) 6.2 patch notes and not seen anything relavant.
CISCO is currently stumped.
