720
Beginner
Nexus 7010 upgrade to 5.1.3 with only 4GB on SUP?
Hi there,
I inherited a 7010 in a pure L2 and single vdc running on a 4GB SUP1 running 4.2(4) .  I have the following questions and am hoping that gurus here can share their insight.  Appreciate any response in advance.
- 5.1.3 release notes 'seems' to indicate upgradeing to 5.1.3 is fine on a 4G SUP1, but the flow chart looks a bit confusing.  Is it O.K.?
- My EPLD is 4.2.4, do I need to upgrade EPLD 5.1.1 for NX-OS 5.1.3?
- Will 5.1.3 work with 4.2.4 EPLD?
- got following message, I have copied the EPLD many times:
switch#show install module 1 impact epld bootflash:n7000-s1-epld.5.1.1.img
Retrieving EPLD versions... Please wait.
Failed to extract EPLD image file, Exiting..
Best regards,
Addy
1 ACCEPTED SOLUTION
Rising star
Re: Nexus 7010 upgrade to 5.1.3 with only 4GB on SUP?
I have 5.1(3) running SUP1 with 4GB, it's supported. I'm not aware of a higher memory configuration on SUP1.
Yes, you absolutely need to upgrade EPLDs to 5.1.1
You first need to upgrade NX-OS before upgrading EPLDs.
1 REPLY 1
Rising star
Content for Community-Ad
July's Community Spotlight Awards
