Nexus 7010 VDC Migration
joet8591
Current config is in the Admin VDC. Is there a way to move/migrate the configuration to a newly created VDC?
(Or just copy and paste the relevant portions.)
Want to use the Admin default VDC only for admin and mgt.
Joe
Oleksandr Nesterov
Hi Joe,
Best would be copy/paste, but previously you will need to move appropriate interfaces to new VDC, copy into notepad and then edit your config and finally paste.
Please carefuly plane further actions (which interfaces to move to a new vdc, on which module and how to configure the,) since for sure you'll need another VDC for your network and reating it will add more diffiulty.
HTH,
Alex
