03-17-2015 12:34 PM - edited 03-07-2019 11:08 PM
Just tried installing a new Nexus 7010, With a couple of F3 line modules.
I cant seem to figure out how to get them to come online.
They flash with red LED and from a "show module" they show as powered down.
Its a fresh nexus install, What could I be missing here? Do I need to "provision them somehow?
L
-Graham
Please note: My comments are simply suggestions. I cannot be held liable for any loss of data, life or marbles due to following my instructions.
Got a website? Need some live chat software?
Solved! Go to Solution.
03-17-2015 01:14 PM
Okay, the "something" is important.
According to the release notes you need a minimum of 6.2(6) -
Jon
03-17-2015 01:04 PM
What version of NXOS do you have and what are the modules ?
Jon
03-17-2015 01:08 PM
Its 6. something ( Im not in front of it right now )
And im certain its these ones.
http://www.cisco.com/c/en/us/products/collateral/switches/nexus-7000-series-switches/datasheet-c78-730273.html
They are 48 port , 1/10G fiber. with "8 port groups.."
No idea if this helps at all.
Its a new install,
It contains the default VDC and an admin user. No other config has been done.
03-17-2015 01:14 PM
Jon
03-17-2015 01:18 PM
Hmm, Ok that "may" be it then. gah. I hate upgrading nexus's
Its the 10 slot version of the 7k im using, it doesnt seme to mention the 48 port module on that page, but yeah I guess it may be related.. ( I cant see why 3 modules would be faulty ) so I guess this is really the only common thing.
Cheers,
03-17-2015 01:23 PM
Edit - sorry I see what you are saying now.
Jon
03-17-2015 01:57 PM
Actually I'm not sure these modules are supported in your chassis.
According to the data sheet for your modules they are only supported in the 7700 chassis.
See table 2 in this link -
Jon
