02-01-2018 12:04 AM - edited 03-08-2019 01:39 PM
Problem in Etherchannel Configuration using Ports of different M3 Linecards
I use two Nexus 7706 with NX-OS 8.2(1); each Device has two Linecards
N77-M348XP-23L Slot 2
N77-M324FQ-25L Slot 5
I want to create a Portchannel between the two devices using the following ports
Eth5/1 contains CVR-QSFP-SFP10G Adapter in combination with SFP-10G-SR Transceiver
Eth2/1 contains SFP-10G-SR Transceiver
Creating Portchannel using following commands results in an error message
dc-gw(config)# int eth2/1
dc-gw(config-if)# switchport
dc-gw(config-if)# switchport mode trunk
dc-gw(config-if)# channel-group 100 mode on
dc-gw(config-if)# int eth5/1
command failed: port not compatible [Capabilities speed]
Setting speed of Eth 5/1
dc-gw(config-if)# speed 10000
ERROR: Ethernet5/1: Configuration does not match the port capability.
does not work.
Greetings Manfred
02-20-2018 10:06 PM
I wonder if the use of a 4 x 10G breakout cable will resolve the issue. I am also considering to propose this to a client, to split the port-channel across the 2 modules to provide some more redundancy, but have not been able to confirm if it works or even supported.
02-21-2018 06:36 AM
02-21-2018 12:25 AM
Have you configured the required N77-M324FQ-25L module interfaces into Breakout Mode? Breakout Mode enables a 40GbE port on the module to be split into four independant 10GbE ports.
Will
02-21-2018 06:35 AM
02-21-2018 05:51 PM
I seek clarification on the more important issue of whether we can bundle into a port-channel a 10g port on the N77-M348XP-23L module with a 10g port out of the breakout cable on the N77-M324FQ-25L. Is this a supported configuration? Thanks.
