Nexus 7K Engineering
cparkinson3
Can anyone point me to some good docs that outline the purpose of fabric, M and F cards?
In paricular I need to know the relationship between M/F cards and how/why I would combine them in the 7K.
EG, if I have X nunber of subnets hanging on Y number of 5548s, split over 2* F cards, how many M cards would I need?
Do M cards load balance for redundancy?  Can M cards do vPC?
Etc etc.
I'd appreciate any pointers.
Chris
baracus11
I am going to assume you are referring to the M1 and F2 series. I wouldn't combine these 2 in the same chassis unless you have a specific reason. They won't work unless you put them in different VDC's. For the most part, the F2 is much better and blows the pants off of the M1. I think the F2 is also less expensive? The M132XP has 80Gb of fabric while the F2 has 550Gb if you stack your 7K with 5 FAB2's.
Yes, the M1's basically combine their forwarding engines into a port-channel.
