Nexus 7K F132 with FAB2
Todd Bren
Hi, my F132 is running at 230Gbps in 7009 and 5x FAB2. Why is this F1 card running at this speed and M2 card is at full 550Gbps?
Datasheets of both cards give their max BW lower than 550Gbps. After all, maybe the question should rather be why the M2 is at 550Gbps
Thank you for any input!
N7K1# sh mod | head line 10
Mod  Ports  Module-Type                         Model              Status
1    0      Supervisor module-2                 N7K-SUP2E          active *
2    0      Supervisor module-2                 N7K-SUP2E          ha-standby
3    24     10 Gbps Ethernet Module             N7K-M224XP-23L     ok
4    24     10 Gbps Ethernet Module             N7K-M224XP-23L     ok
8    32     1/10 Gbps Ethernet Module           N7K-F132XP-15      ok
9    32     1/10 Gbps Ethernet Module           N7K-F132XP-15      ok
N7K1# sh hardware fabric-u
Slot        Total Fabric        Utilization
            Bandwidth      Ingress % Egress %
1             275 Gbps          0.00     0.00
2             275 Gbps          0.00     0.00
3             550 Gbps          0.00     0.00
4             550 Gbps          0.00     0.00
8             230 Gbps          0.00     0.00
9             230 Gbps          0.00     0.00
Jose Solano
Level 4
Level 4
See this below:
Cisco Nexus 7000  F1-Series 32-Port 1 and 10 Gigabit Ethernet Module Date Sheet
Fabric Interface
Switch fabric interface
• 230 Gbps in each direction (460 Gbps full duplex) distributed across five Cisco Nexus 7000 Series fabric modules with 46 Gbps per slot
• 320-Gbps switching capacity, per module, in meshed architecture
http://www.cisco.com/en/US/prod/collateral/switches/ps9441/ps9402/data_sheet_c78-605622.html
Cisco Nexus 7000 M2-Series 24-Port 10 Gigabit Ethernet Module with XL Option Data Sheet
Fabric Interface
550 Gbps in each direction (1.1 Tbps full duplex) distributed across up to five Fabric-2 modules
230 Gbps in each direction (460 Gbps full duplex) distributed across up to five Fabric-1 modules
http://www.cisco.com/en/US/prod/collateral/switches/ps9441/ps9402/data_sheet_c78-706775.html
Hope this helps.
Jose Solano
Level 4
Level 4
See this below:
Fabric Interface
Fabric Interface
Hope this helps.
Leo, thanks for the link, marked as correct.
To add I used this table for my comparison:
http://www.cisco.com/en/US/products/ps9402/prod_models_comparison.html#~tab-b .
There M224 is 240Gbps and F132 used to have 230Gbps. Interestingly that FAB2 enable 550Gbps on M2 but not on F1.
