Nexus 7K mtu - interface mtu or policy-map type network
peterbe
Beginner
Beginner
We currently have the interfaces configured with 'mtu 9216'. Now we are adding a policy-map type network for the data and iSCSI classes.  Where do we set mtu - see example
interface e8/1
mtu 9216  << with this set, do we need to specify mtu in the policy-map?
policy-map type network-qos CONVERGED-DATA-ISCSI-NQ
    class type network-qos C-NQ-DATA-DROP
      congestion-control tail-drop
      mtu 9216  <<  Is this needed
    class type network-qos C-NQ-ISCSI-NODROP
      pause
Is one method of setting mtu prefered over the other?
thanks
Peter
2 REPLIES 2
Reza Sharifi
Hall of Fame Expert Hall of Fame Expert
Hall of Fame Expert
You don't need a policy-map to set the mtu, just the mtu command:
mtu 9216
verify with sh int ex/xx
Thanks Reza.
I configured:
      pause
But a show:
sh policy-map type network-qos CONVERGED-DATA-ISCSI-NQ
  Type network-qos policy-maps
      mtu 1500
      pause
      mtu1500
So configuring the policy-map defaults mtu to 1500 if you don't specify a specific mtu.
What takes preference, the policy-map mtu or interface mtu?
