Hello team,
i would like to know if in a cisco 7k this config are correct :
switch port mode access
switch port access vlan 516
spanning tree portfast edge
switch port trunk allowed vlan none
because we got tree interface to Cisco ISE servers , two interfaces (1/6 1/7) with this previous config and one of them (1/5) without (switch port trunk allowed vlan none)
issue : the interface 1/5 without the trunk allwoed vlan none was NOT CONNECTED and can't see MAC of ISE server
resolution : we removed the line : switch port trunk allowed vlan none in the two interface , and after that the interface comes UP
i would like to know what is the relation between the issue and how we solved it ?
Thank you in advance
Best Regards
