Nexus 7K SPAN port and NetOptics SPAN Regen Tap
I have configured a 10G SPAN port on my Nexus 7010 and connected it to a NetOptics SPAN regeneration tap. I am unable to get the SPAN session to come up. When I bypass the tap and connect my monitor server directly to the SPAN port on the Nexus, it works fine. NetOptics tells me that the tap SPAN port is RX only and I believe that because of this my SPAN port is not coming up when connected through the Tap. Is there a way to force the Nexus port up, or has anyone run a similar configuration?
Nexus config:
monitor session 1
  source vlan 160,184 both
  destination interface Ethernet2/18
  destination interface Ethernet2/19
  no shut
***directly connected to server and up
  switchport
  switchport monitor
  no shutdown
Ethernet2/18 is up
  Hardware: 10000 Ethernet, address: 44d3.cab9.ee89 (bia 44d3.cab9.ee89)
  MTU 1500 bytes, BW 10000000 Kbit, DLY 10 usec
  Encapsulation ARPA
  Port mode is access
  full-duplex, 10 Gb/s, media type is 10G
  Beacon is turned off
  Auto-Negotiation is turned off
***connected to tap and "down/down"
  switchport
  switchport monitor
  no shutdown
Ethernet2/19 is down (Link not connected)
  Hardware: 10000 Ethernet, address: 44d3.cab9.ee8a (bia 44d3.cab9.ee8a)
  Encapsulation ARPA
  Port mode is access
  auto-duplex, auto-speed, media type is 10G
Askeptic
I've got a similar issue with an N9K switch. I need to be able to "force-up" a monitor port due to an RX only SFP on the other end. Funny that Cisco makes such SFP's but doesn't support them.
